Question about Panasonic Lumix DMC-LZ2 Digital Camera
Where do I charge up the battery on my Luminex LX8OZ camera
I have the above model camera and manual. It is telling me to charge the battery but there is no where on the camera to place a lead to recharge it. Does this mean I have to replace the the internal battery. I have only had this a couple of months and used it for the first time when I went on holiday two weeks ago.
  • 79 Answers
Please confirm your manuel how to chargr the battery
Posted on Jun 20, 2009
    Sergeant:
  • 321 Answers
NiMH batteries charger u get externally
Posted on Jun 18, 2009
6ya staff
SOURCE:
How do i charge my kodak 8.0 digital camera
What model Kodak 8.0 megapixel camera? The M1063 is a 10 megapixel model.
Some Kodak cameras can charge the battery when you connect the camera to a power source. Some Kodak cameras come with a separate battery charger. Some Kodak cameras use disposable batteries. Without knowing the model of your camera I can't tell you how to charge your camera.
Jul 15, 2014 | Kodak EASYSHARE M1063 Digital Camera
How do I change the resolution on a Panasonic Luminex DMC-ZS20
Press the MENU/SET button. Use the cursor keys to select the REC menu and press MENU/SET. Use the cursor keys to select Picture Size and press MENU/SET. Use the cursor keys to select the desired size and press MENU/SET.
If you need a manual, you may download a copy here.
Jul 05, 2012 | Cameras
When I'm trying to charge the battery for my Olympus u790sw camera the light on the charger flashes red... previously it was just a solid red when charging?
Not familiar with this model but on other camera chargers I have used it flashes red while charging then goes green when it's charged, it should tell you this in the manual about charging the battery
Jun 05, 2011 | Cameras
Hi I have the vivitar vivicam 8025 dont have my manual want to know how to charge my battery
First off, you can download a PDF version of the manual from the manufacturer at: http://www.vivitar.com/files_products/13/VC8025%20User%20Manual.pdf
If you don't have a PDF viewer, you can download one from: http://www.foxitsoftware.com/pdf/reader/ (just click download under the free version)
For your convenience I've pasted the relevant information about charging the batteries from the above manual:
Please charge the battery as below 2 methods: A. Charge with USB cable Insert the lithium battery into your camera correctly, and connect your camera to computer with USB cable. The red LED of camera will be light on indicating that your camera is in charging status, the LED willbe off when charge full.
B. Charge with supplied charger Your camera is supplied a compatible charger for you, you are only required to put the battery into charger and charge the lithium battery directly from electrical outlet
Please leave feedback if this was helpful. Thanks.
Apr 11, 2011 | Vivitar Cameras
Hi I have a Panasonic Luminex DMC-TZ%, but everytime i swap the battery the time date function re-sets to zero: 1 jan 2000, just like an old 35mm film camera when the internal battery when flat. Any ideas...
There is probably an additional battery (usually a button battery) that keeps the internal memory going when there is no battery. It needs to be replaced.
Aug 12, 2010 | Cameras
They charge gets over very soon,even replaced the batteries
Please provide the correct camera model. If it is the Sony model mentioned then it uses an Infolithium battery pack which is charged in a very different manner then the one detailed above.
If the model is wrong and you have regular NIMh batteries then charge them for atleast 10 hours if using 2100 mah or above
Aug 21, 2009 | Kodak EasyShare Z710 Digital Camera
How can i tell if i need to charge my battery for kodak m1063
a lil battery sym ol will start flashing in the lower right corner
Jul 01, 2009 | Kodak EASYSHARE M1063 Digital Camera
How do you change the battery in a series 3100 luminex navy seal
Take it to a reputable jeweler, this model has a screw off back and you need a special tool to remove it...good luck :)
Jan 26, 2009 | Luminox Navy Seal Dive 3001 Wrist Watch
INSTRUCTION MANUAL PDF FORMAT
The Manual is on the Disk that came with the camera.
However this wont tell how to change the internal 'clock battery'
This is a workshop job and will be quite expensive I would guess
Dec 10, 2007 | Fuji FinePix S5000 Digital Camera
Cyber-shot 3.2 mega
have the above camera, the problem i have is that the lent does not open even if the battery is full charged. just keeps telling me to trun off the power n trun it back on but it still dont open
Oct 06, 2007 | Sony Cyber-Shot DSC-P52 Digital Camera
Panasonic Lumix DMC-LZ2 Digital Camera Logo
108 people viewed this question
Top Panasonic Cameras Experts
Ekse
rajiv6089
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
