SOURCE: feedback
That is a great mic. It has a lot to do with the room your in and acoustics of it. If you are too close to your PA or monitor, it will also feedback. Lowering treble and reverb will also help.
SOURCE: shure sm58
Hi danny
There not that much to take apart on the sm58. On page 2 of the user manual there is a wiring diagram to reconnect wires. the grill wind filter part screws on. The socket on the bottom is secured with a screw.
I am more than happy to answer any other questions you may have about
it, please get back to me here, or use the ASK function to go straight
to me :) If you are still unsure, have problems, or we need to look at
the situation more deeply, then before you give a rating for this
advice, hit the ASK button
Thanks for using FixYa, If you consider the advice I have given you as
sound, a FixYa rating is a great reward for my efforts to help you.
Cheers.
regards
robotek
SOURCE: re-solder shure sm58
If you're careful, you can solder it yourself.
Just solder some thin wires to the lose ends.
After soldering use some cellotape to isolate the solderingjoint and to attach the wires to the element.
If you're not familiar with soldering tiny things, please don't. Any technician can fix it for you.
Good luck,
Gerard
SOURCE: hi i have this system
The LX series was discontinued by Shure several years ago. They no longer have any new transmitters that would work with your receiver. You could look for a used transmitter, but it would need to be on the exact same frequency as your receiver. That will not be easy to find.
