Briggs & Stratton Gas Pressure Washer 20244 Logo
A
Anonymous Posted on Apr 13, 2014
Won't Start I have a pressure washer that the pull line will only pull out so far and won't start the engine. I seams to be frozen.
3 Related Answers
andy just round the corner
  • 47 Answers
  • Posted on Jul 21, 2009
SOURCE: pressure washer hesitates, does not start. Unable
get someone to keep the trigger pulled while you try to start it , its probably got presure trapped between the trigger and the pump.
alternatively turn off the water to the pump, pull the trigger to release any pressure trapped.
start the engine , allow engine to warm up, increase revs on engine then turn on water, should be ok then. Unless you have a problem with the engine that is!
Anonymous
  • 316 Answers
  • Posted on Feb 22, 2012
SOURCE: Briggs and Stratton pressure washer will not
hello dave, the problem is compression to low,you need 60 to 130 lbs to run engine,check for blown head gasket,or bad rings,or a stuck open valve,hope this helps,,
Anonymous
  • 6468 Answers
  • Posted on Jun 25, 2012
SOURCE: craftsmen, power washer, 2800 psi, won't start when hot.
when it cuts out check for spark the coil might be bad
2answers
Won't start
Are you saying that it WONT start or that you cannot pull the rope to get it to start?
I have a 89 ford ranger it won't start it acts
What have you checked so far ?
Is it getting spark to the plugs ?
Can you spray starting fluid into the throttle body and get it to start ?
Have you checked fuel pressure at the injectors ?
MIne Whirlpool duet is having probloms please help me with it!
see this causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Kenmore Elite Model 110.42926 202 after setting the desired cycle will not start when you push the start button
I has a Crosley Washing Machine Top Loader. Fill light comes on lid locks then NOthing!
seethis causes and fix it. God bless you
When you push start button nothing happens
2helpful
My Kenmore H3T washer will not start. When a specified wash cycle is chosen Time of Cycle is displayed but the light for the cycle only flashes and washer will not start. No error code is displayed.MO
1993 GMC Jimmy won't throttle up..changed fuel pump...sounds like fuel is running back into tank
Check fuel pressure regulator.Start engine hook fuel gauge to fuel line check pressure ready then pull the vacuum hose of the fuel regulator if pressure rises 5-10 psi then its good.
2answers
New Karcher pressure washer won't start
replace the fuel carburetor filter and, or, your fuel tank filter
Top Briggs & Stratton Garden Experts
Jay Finke
Jay Finke
john h
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
