Nikon Coolpix 8800 Digital Camera Logo
Posted on Jun 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Date and Time problem
I set the date/time and all goes well but as soon as I turn the camera off and on again this function goes into a ""random state" showing completely wrong times and dates.
Very annoying, since it forces me to set the date and time before each shot.
Can the Nikon Guru or any one help me ?
mohamed salim shaikh
Level 2:
Sergeant:
  • Expert 321 Answers
  • Posted on Jun 18, 2009
Expert
Level 2:
Sergeant:
Answers
321
Questions
0
Helped
81059
Points
726
Set your date and time 24HRS. setting off ur cam and then remove batt to charge
1helpful
2answers
How to date change in camera for display see date
Switch on the cameraPress MENU at the back You will 2 icons. One for camera and other for tools. Select tools settings
Scroll down to Date & Time settings. Press Set/Function. Change the date and time as per our time zone. Press again Set/Function. For display of date Select camera icon and on the drop down menu select display. By pressing the function key select the date /date and time. Press Set. The camera is set. Whenever you view picture it will display the date and time
2helpful
I received a canon powershot as a gift last year and am just now really starting to use it. The pictures seem fine, but the it seems like I am frequently requested to put in the date and time (i.e. about...
There is a button battery in your camera (CR1220) that remembers the date and other settings when you remove the main batteries. It probably needs to be replaced. It's in a slide-out holder next to the AA batteries (see page 184 in the manual).
You turn on the date stamp by using the photo size settings. Press the Function key and scroll down to the bottom item (usually L). Then scroll over to the Date Stamp icon (to the right of the L, M1, M2, M3, S options). Press the Function/Set key again.
1helpful
My M863 changes the date intermittently to a random date & if I don't see the date when turning on the camera it dates the pic's incorrectly. Thanks.
hello,
Everytime you removed the battery of your camera, date and time will be reset. You have to set the date and time correctly.
Follow the steps below.
1.Press the Menu button.
2.select the Setup Tab, it has camera w/ tool icon
3.Scroll down until you select Date and Time
4.Press Ok then set the date and time.
Thanks.
Neerak21
1helpful
How do i set the time and date to stamp on my pics for canonsd870 is
hi the following procedure is to set the date and time...
just do the following steps carefully.
1. Push the function/set button. Press the directional button down to select Date and Time.
2. Push the directional button to the right then down or up to set the date and time. Then press the function/set button to save it.
Then: to put the date and time on your pictures,
3. Push the selector button up to the camera icon, and press function/set. Scroll down to Date Stamp.
4. Scroll right to turn on the Date and Time Stamp, then up or down to until it says On.
Press function/set when your done.
That is your solution.after u set the date/time stamp is embedded in a picture, you can't take it out. ...
thank u
rate me
I DONT WANT MY CAMERA TO HAVE A DATE...IT SHOW WHENEVER I PRINT MY PHOTOS. HOW CAN I REMOVE THE DATE? PLS. HELP.THANKS
hi the following procedure is to set the date and time... just do the opposite of dis and ur date and time will be removed..
thank u!!!!
13helpful
2answers
Canon sd 750 how to put the date in the picture?
here is the solution:
The date and time can be included on the pictures taken only with the camera in postcard mode. You must also activate the date stamp option in the menu.
To set the camera into postcard mode, press the [Func.] button on the camera, then use the [arrow down] key to go down to the last option in the menu, and there you can choose the [Postcard mode]. Press [Func.] again to exit the function menu.
To set the date and time stamp, press the [Menu] button and then use the [arrow down] button to go to the [Date stamp] option in the menu. You can set this to "Date" or "Date & Time". Press the [Menu] button again to exit the menu.
dsc_include_date02_tcm14-520511.jpgyour date and time are set now
congratulations!
Rate this answer if it is working with you
thank you
with all my best regards
[email protected]
Can't get the Date off the Pictures
First you have to go to the set up menu and set the correct time and date, then you can go back to the settings and select OFF for time and date. If you do not set the correct time and date , that default date stays in the picture.
2helpful
Date to appear on photo
Set the image size to 'postcard'. Press the Function key, scroll down to the bottom icon and select postcard (L, M1, M2, S, postcard). Press Function key again.
To turn the date imprint on, go to the Record menu and set the option for Date Stamp to Date or Date & Time.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
