SOURCE: Hi Hope you can help me. I have a Franke Flair
The problem is probably a damage boiler heating element. It have brake out at a point so it making electrical contact with water and so with body and finaly with earthing of the electrical system and thus trips the main fuse which is the erthing protection system.
So you need to replace the heating element. You need also a good inspection to find if their is another reason why the heating element blow up or if its just because of exeed use of the machine.
Good Luck
SOURCE: I have a franke flair coffee machine when you
DESCALING
The Saphira has an integrated descaling program. The procedure takes about 60 minutes.
Once started, the descaling procedure may not be stopped.
• When acid-containing descalers are used, immediately remove any splashes or drops on
sensitive surfaces, particularly from natural stone and wood surfaces. Also, take the appropriate safety
precautions.
• Turn off the Saphira by pressing the "ON/OFF" button.
• Press the button "Descale" until an acoustic signal is heard.
• Display: EMPTY
DRIP TRAY (Fig.1)
• Display: INSERT AGENT
IN TANK
• Display: PRESS
DECALCIFYING
Dissolve 2 DESCALING tablets completely in 2.5 cups of water in a vessel and pour the mixture into the empty
water tank.
Place a sufficiently large container under the steam tube and the coffee delivery outlet.
• Press the Descale button
• Display: UNIT
DECALCIFYING
• Display: PLEASE
WAIT
• An acoustic signal is heard.
• Display: EMPTY
DRIP TRAY (Fig.1)
• Display: FILL
WATER TANK
• Display: PRESS
DECALCIFYING
• Display: UNIT
DECALCIFYING
• Display: PLEASE
WAIT
• Display: EMPTY
DRIP TRAY
• Display: CLEAN
CONTACTS
Good Luck
[email protected]
SOURCE: how can I get different
Here's a link with a training video for the Flair which is on our website
Denby Dale Coffee
Franke Flair Video
