SOURCE: Converting From 12/24 to Starght 24 Volt
The batteries must be connected in SERIES. The method described is proper, but the name of the method is wrong.
On the female plug for the motor on the boat, if you have the wiring for TWO separate batteries coming to the plug, the male plug must have a jumper in it. To find out, disconnect the batteries one at a time and voltage check to see if there are two separate battery systems there. There probably are. If so, the series circuit is provided for in the male plug by the jumper and not in the back of the boat where the batteries must be wired independent of each other.
SOURCE: Mounting a sonor/transducer on a MinnKota Riptide ST
Did the unit come with a strap to mount the transducer to a bow mount electric? Most units do... If not there is probably one available for the unit as an aftermarket accessory or accessory from the manufacturer... Regarding the transducer wire, just wrap and rout this up the front of the bow mount motor shaft so when you pull the motor up and secure it, it is not going to get in the way. You could cable tie the cord down near the bottom of the shaft and one up near the top where they wont interfere with the motor bracket when the motor is positioned up on the boat.
SOURCE: minnkota trolling motor prop removal
remove the nut and the prop will come right off. Just be careful not to loose the shear pin.
