Jenn-Air 30 in. CCE3401 Electric Cooktop Logo
A
Anonymous Posted on Apr 13, 2014
Using front left burner back burner will turn on without turning knob for left back?
Jorgie Navito
Level 3:
Master:
  • Jenn-Air Master 357 Answers
  • Posted on Mar 17, 2020
Jorgie Navito
Jenn-Air Master
Level 3:
Master:
Answers
357
Questions
0
Helped
108916
Points
2245
SOUNDS LIKE THEY ARE HOOKED UP WRONG CHECK THE HARNESS SWITCH CONNECTIONS OR YOU MAY HAVE A BAD INFINITE SWITCH
Using front left burner back burner will turn on w - infiniteswitch_stove_switches2-undefined-undefined-0.jpg
infinite switchs stove-uUsing front left burner back burner will turn on w - oven harness ge-switch-ignition-harness_l-undefined-undefined-9_0.jpgploads/images/oven harness ge-switch-ignition-harness_l-undefined-undefined-9_0.jpg
3 Related Answers
gerbee gomez
  • 222 Answers
  • Posted on Jul 04, 2009
SOURCE: Jenn-Air 36 Gas Cooktop
try to use macth in the burner u said,if ok the flame,the problem is the igniter wire,nid to replace,but if u use the macth then the flame is malfunction again i think the sensor is the problem,nid the tecnician coz is hard to repair,sometime after repair the sensor it problem again in next day
tnx gerbee
Anonymous
  • 59 Answers
  • Posted on Jun 15, 2010
SOURCE: When I push down and turn the knob to
You might need to hold it down for a few seconds if the cook top has automatic flame detection. A bi metal strip (or some other form of thermostat) near the burner will need to heat up before the burner can lock on.
Anonymous
  • 43501 Answers
  • Posted on Aug 18, 2010
SOURCE: burner valves stuck and will not turn.
They are not that hard to replace and you can easily buy the part online...
Here is a tip about how to buy appliance parts online.
How to Buy Appliance Parts Online
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
heatman101
Whirlpool SC8720EDB cooktop stove independent vent switch is not starting downdraft exhaust fan, but the exhaust fan works fine when left side burners were turned on
Can you get to the switch terminals and try jumping them out with a piece of insulated wire? That would tell you if the switch is defective (my suspicion). Please be careful not to touch any live terminals - only the wire insulation you use for the jumper.
Whirlpool How To
so sorry for the way late reply!
if the knob does not fit you'll need a new one...
i found them here....
https://www.repairclinic.com/Shop-For-Parts/c31-x72636333303234/Rcc3024-Knob-Dial-Button-Parts
not sure which is yours as the model # should have a few more # or letters. Take a look at them and see if one matches.
best to you.
Just purchased Ilve Ceran ceramic cooktop. Is V364X the cooktop model number?The outer are of the left front burner does not heat up
You may already be aware of this but ... If our ilve ceran cooktop is the same as yours turn the knob past the 12 setting till you feel pressure and it springs back. This is the switch to fire up the marked outer elements.
Mar 11, 2012 • Cooktops
Dead burner on kitchenaid gas cooktop?
it is strange that you have no gas and no spark! if you held a match to the burner and turned the burner valve on it would lite di spite a failed ignitor,but for it not to lite, the burner valve[its what the knob attaches too] would have to be blocked[thats rare]or ........i got it .....the knob is broken.thats the only thing the burner valve and the spark ignitor have in common.try a knob from another burner................again.you have spark,because others are working.spark on troubled burner would work if valve blocked at orifice outlet,and if spark failed you would still get gas they work independent of each other,[but in unison].thats why im thinking knob.its the item that works both .when you turn the knob it opens the gas valve and as the gas valve rotates by turning the knob it activates or turns the spark switch so it closes the curcit allowing the electricty to the spark moduel.hey i hope that helps a little. God bless ,tom
2helpful
Ignition problems
It sounds like the round burner orifices are dirty. Remove the round orifices and clean in warm soapy water, using a plastic scrubber or toothbrush to remove and dirt and residue around the sides of the burner. Do the same on the little electrode that protrudes at some position around the burner orifice seat.
The system works by the spark ignition module knowing a gas knob is open, and sensing for a flame by ionization within the exhaust gases of the flame. If things are dirty, then the module cannot read the ionization and shuts down the burner, and will also cause the spark to continue.
Also make sure all the burner orifices are properly seated in their holder. If not, the same thing will happen.
Viking Gas Burner issue?
is this a sealed burner unit? if so the burner base (the heavy brass part under the burner cap) has to be sitting just right. you will notice that it has holes around the the sides make sure that where your ignitor sparks to it that it aligns with the lowest hole on the burner base. if you have a great flame all around the burner after checking what i mentioned i would replace the spark module. if it continues to drive you crazy with the noise - just unplug it. the burners will continue working fine without power.
2helpful
Ge profile ceramic electric cooktop
No recalls that I know of.  The switch for that burner has shorted and will need to be replaced.  It will be fine once it is repaired.
Top Jenn-Air Cooktops Experts
Paul Carew
Paul Bade
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
