Frigidaire Affinity ATF7000E Front Load Washer Logo
A
Anonymous Posted on Apr 13, 2014
Error e38 washing - Frigidaire Affinity ATF7000E Front Load Washer
How do i clear er38 error message
Could be anything. When does it make the noise? Check the cv joints
Why washer will not do diagnostic test or erase E38 error code
[PDF]Fault Code Bible v1.2 - ResearchGate
www.researchgate.net/publictopics.PublicPostFileLoader.html... ResearchGatesimple, clear instructions on how to read the faults or use the diagnostic routines. .....Resetting the error indication does not rectify the fault but only erases from .... E53 Input circuit EMC errors Displayed as error code, washing machine start ... if you choose position 10, 11 or 12, the test will terminate without pressing.
E38 error code
Hi Friend, thank you for allowing me to assist you!
Typically an error code E38 on your Frigidaire washer could mean a few things:
First see if the air trap is clogged. If it is, that is probably the most likely issue.
If it is not clogged, it could either be the main control board, the water valve assembly or the pressure sensor switch.
To make sure it is not a false error code, reset the power to your appliance by either unplugging it or flipping off the breaker for about 30 seconds.
If the error code continues to display, I would strongly recommend contacting a professional to make the necessary repairs. Unfortunately, most electronic parts cannot be returned so it is always a good idea to get the appropriate diagnosis prior to making any unnecessary part replacements.
Best regards! - Z
ERROR E38
Found manual here with all error codes. It's in Russian though..
http://www.rservice.by/files/manual/cassida/counters/Cassida%20Billcon%20N120%20User%20Manual%2028.11.2013.pdf
Bmw technical problems
There will be error codes but the CPU is not being accessed correctly for the readings. The problem will most likely be in the TCM
1helpful
I have a Frigidaire Affinity front load washer Model ATF7000ES0 and am getting error code E38
Hi Scott Brown: Typically an error code E38 could mean a few things:
· First see if the air trap is clogged. If it is, that is probably the most likely issue.
· If it is not clogged, it could either be the main control board, the water valve assembly or the pressure sensor switch.
· To make sure it is not a false error code, reset the power to the appliance by either unplugging it or flipping off the breaker for about 30 seconds.
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
