On Thursday I tried to record a program on VHS. After the recording was over I tried to return to cable TV with no luck I went into the menu mode of the Phillips Recorder,there are only 5 modes. Timer record did nothing, so I went into Satellite Link, the time flashed and then said on. How do I get off of sat and back to the cable connection so I can watch TV again. Why would one recording cause a problem. If I am going out for the evening which do I use one-touch record or time record and does the cable box have to be on inorder to record?
SOURCE: Philips Magnavox MWR10D6 DVD Recorder Cannot record in +VR mode
check to see if the U-verse box is in HD mode. If it is, change it to standard definition and the problem should be solved.
Menu -> Options -> System Settings -> Aspect Ratio
SOURCE: zv420mw8 magnavox vhs to dvd recorder
I have lost my remote to my Digital Video Disc Recorder with Videeo Cassette Recorder #ZV420MW8. I would like to know how to go about getting a replacement. Thank You, Diane Wotton [email protected]
SOURCE: DV220MW9 DVD/VCR: won't record video on VHS
your cable tv connect into dvd/vcr,video/audio out connect to av in your tv,solved
SOURCE: I have a Magnavox ZV427MG9 A VHS & DVD Recorder
Ensure that your source is correct. L1 is the rear inputs and L2 is the front inputs. If you have it set to L2 then you have no information from the TV getting to the recorder.
SOURCE: this program is not recordable in +vr mode
This means exactly that these are copy Once only, meaning you can not make it copy say 10 copies, at the same time, it means you must do one a at a time. If you wanted say 10 copies, you must do the entire process over and over.
Testimonial: "THANK YOU SO MUCH, THIS LEADS ME IN THE RIGHT DIRECTION, I GUESS I NEED TO CHECK THE SETTINGS ON MY PLAYER"
