Computers & Internet Logo
A
Anonymous Posted on Apr 13, 2014
How do I turn off mute? - Studio Dell Computers & Internet
How can I turn off the mute function?
If it is a VTech phone ( CS6429 or similar )
press the [mute] button again: it is a toggle.
First press of [mute] turns mic off (mute-on).
Next press of [mute] turns mic on (mute-off).
Unmute handset
Mute Microphone
With the handset
You can temporarily turn Off the microphone so that the person you are talking with cannot hear you.
1)Press menu/del during talk mode (while phone is in use).
2)Press ring/vol/? or ring/vol/? to move the pointer to Mute and then select/
Mute On and appear in the display. To cancel muting, repeat above step again when Mute
is set to on, Mute Off appears.
With the base
While using the base speakerphone, press mute on the base to turn Off the microphone.
Press mute again or press (speaker) to cancel muting.
Www urcsupport com
Does your TV have a "half-mute" setting:
* press MUTE once to reduce the volume to 50%
* press MUTE a second time to reduce the volume to zero
* press MUTE a third time to restore the volume to 100%
1helpful
2answers
My radio is stuck on mute. How do I turn the mute
Where is the mute button on an RFX9500?
2answers
Mute button wont turn off
HERE is your manual in PDF format.
This unit doesnt have a volume mute function.
What are the problems you are experiencing.
If it says Mute or ATT on the display - it is the cellular mute function turning off the volume for an incoming call.
Page 34 details turning on and off the cellular mute function.
You also may try a hard reset by removing the face, and pressing the reset button.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question
TV TURNS ITSELF OFF WHEN MUTE IS ACTIVATED
Try a different remote, your remote may be putting out the wrong command when you press mute. Will pressing mute turn the TV on?
Mute - Turn On??
Welcome to Panasonic :-)
The mute button works when you have a speakerphone call. That means SP-PHONE pressed and press MUTE and it flashes to let you know it's on mute.
Maybe software version 9.0 will fix the mute to work on handset calls.....
Carl
Can't turn off mute on panasonic phone
[Mute /Auto Answer] is a dual function button.
Mute flashes when it is on and Auto Answer lit solid. Both of these features toggle on and toggle off. Auto Answer will turn on and off during the on-hook condition. Mute is employed during call.
If these lights are not associated with the Mic working, you may have a bad set.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
