Question about Hotpoint Aquarius WF220 Front Load Washer
Pumps out but wont spin fast enough
Pumps out water but doesnt spin fast enough
Maytag Neptune Front Load Washer Model MAH5500BWW
You say your belt is a little loose. When the motor starts to spin the belt may become more loose, causing the belt to not spin the pump at full capacity. I would suggest you change the belt. I think you will find your problem. Good Luck Friend.
Sep 24, 2018 | Maytag Washing Machines
What causes the water not to spin out of the clothes?
Hi, it means that the machine is not spinning fast enough and pumping the water away. If its not spinning enough then you have to get the machine looked at as its not clicking on in the cycle for it to spin fast enough. You also have to have it set to wash cycle that has a fast spin. If it is spinning fast then you have to look at the pump to make sure its pumping the water away.
Mar 18, 2016 | Washing Machines
Speedqueen awm270-3062 why does machine cut out on spin cycle and when u manualy remove water it then spins
either the water doesnt get pumped out fast enough
or the motor has an issue prob its brushes need replaced
Dec 10, 2014 | Washing Machines
Water will not drain out after wash
Check to see if the drain pump is getting to a high spin, if the impeller is stripped wont spin fast enough to push water out
Mar 05, 2014 | Kenmore Dishwashers
OK- my Kenmore He2 won't spin fast enough to drain when there is a heavy load involved. This is what I've done- emptied the filter- lots of change and other gunk, cleaned out attached hoses and the p
Check the shocks on the drum to make sure they are ok. if they wear out the drum spins out of balance and the computer wont allow it spine because it would WALK and damage itself.
Apr 19, 2017 | Kenmore HE2 Plus Front Load Washer
My washer doesnt seem to be spinning fast enough to drain water out of the cloths.its draining fine but the drum wont spin fast enough. is the motor wearing out due to too heavy loads, and what should i...
Thanks for choosing FixYa and welcome. You do need to check the motor drive. Make sure the belt is not slipping or worn. That could be the case. It may be wearing out as you have suggested. You just need to get to it and determine the cause.
Apr 15, 2011 | Whirlpool GHW9400 Duet Washer
Whirl pool washing machine doesnt spin dry
If it wont spin at all, check the lid switch. If it will spin but not fast enough to spin the water out of the clothes, it sounds like the clutch could be slipping.
Aug 08, 2010 | Whirlpool Washing Machines
Maytag Performa agitates, but wont spin corectly.
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 07, 2010 | Washing Machines
Will not spin fast enough on final spin cycle to
ITS POSSABLE ITS NOT PUMPING FAST ENOUGH. CHECK THE DRAIN HOSE AND MAKE SURE IT HAS NO KINK. IF THATS OK IT MAY HAVE A BUILDUP OF SOAP. RUN A EMPTY CYCLE WITH NO SOAP. IF THAT DONT WORK YOU NEED A REPIARMAN TO CLEAN OR REPLACE THE PUMP.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
May 15, 2010 | Maytag Neptune MAH5500B Front Load Washer
Kenmore 90 Series washer needs two spins to remove water
We have exact same washer. It is 11 years old. We are at a point where we have to spin it 7 times and then still isn't too dry. It dies yesterday a very loud death. Mentioning this here because it could be a foreshadowing of your Kenmore 90's future.
Dec 29, 2008 | Washing Machines
Hotpoint Aquarius WF220 Front Load Washer Logo
212 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
