SOURCE: Antenna
Radio Shack carries various replacements. Make sure you know how your broken one mounts because they can look the same, but there may be a variation that will prohibit you from connecting it. If you can, take the broken one with you to match up. If they do not have it, check with a local electronics shop. They may also have a replacement for you.
SOURCE: CD player on boombox
The laser is dead or damaged. Try swabbing the laser with rubbing alcohol on a Q-Tip, then IMMEDIATELY blowing dry with canned air. If this fails, the laser is dead. If it is a Sony KSS-2xx series laser (try to peek in the laser slot to see the decal on it) you can get replacements online. If not, it's junk.
SOURCE: broken antenna
The Sony part number is: 175422611 and the part is available for $15.95 from tritronicsinc.com or any other Sony parts distributor.
Dan
SOURCE: I purchased a Bosch PB10-CD Radio/CD Boombox and
Go here they are about 3bucks eReplacementparts.com
