Continous loop restart.
SOURCE: I have an emachines El-1352G-41W What
If you mean AutoCAD then you need the following:
You can get more information at:
http://usa.autodesk.com/autocad/system-requirements/
For 32-Bit AutoCAD 2012
SOURCE: does my emachine el1352g-41w have
this specific model touts itself as being "multimedia" and as such does have an onboard audio{1 x headphone-out jack, 3 x audio }
it would be a small round green colored plug for the speakers red/pink for the mic in the back and there is a plug at the bottom in the front for the headset and mic.
GL
hope this helps
Don't forget to vote for me
Thank You
Jammer
SOURCE: I have an eMachines EL1352G-41W.
Welcome to Fixya
Try this procedure: Go to your Computer Bios Setup (press Del when you turn on the compute).Go to
"Power Management Setup" and enable " PWron/Resume by alarm" and set
date alarm and time alarm and then press F10 to save your change and
turn off your pc. Observed the pc if it will turn on.
If no PC will not respond then you might need to do a firmware upgrade otherwise you have a faulty motherboard.
Thank you for using FIyxa!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
