I don't see any timing marks on the two counter-balance weight cams, but assume they need to be in sync with the piston. How is the timing accomplished? Thanks!
I believe it is either one but if you are not sure, stick a screw driver in an see if it comes out with oil on it. Does one not have an oil level stick attached to the cap?
If you will e-mail me at [email protected] I can send you some literature that should help
There are 2 oil caps at the bottom. 1 is black, 1 is white. What oil goes where? honda gx340 pressure washer
I posted as having a problem timing a Honda engine. Don't know why it was listed under a problem with a pressure washer.
