On a desktop it's easy to replace the sound card. Remove the power cord, open the case then purchase a PCI Sound card that will fit into one of the PCI Slots. You present sound card might be what is called an on board sound card (which is built into the motherboard). You won't touch the onboard sound card, you will simply add a pci sound card.
It's either your sound card is defective or you are not using the correct sound card device driver. You must state the brand/model of your sound card if this a extension card or state your motherboard model if the sound card is on board. If your unit is branded, you should be able to download this from the manufacturer's website.
If your sound card is defective, just replace the sound card. If its on board the motherboard, disable it from the BIOS and buy an extension card.
1. Locate na expansion slot in your computer that will accept your sound card. 2.Gently place the sound card on top of the slot. Line up the pins
on the sound card with the slot and push the card down so that it sits in the
slot. Be sure that the card is securely in the slot and pushed all the way in. 3.If your computer has an audio cable that connects the CD-ROM drive directly to
the sound card, locate it and plug it in to the card. Consult the documentation
that came with your sound card to determine the location of the CD-ROM audio
connector on the card. This cable is rarely necessary with current
audio hardware.MORE INFO.IN NEXT SLOT
1st you disable the onboard sound card in BIOS level, then install/update the sound driver for Maddog Prowler 4.1 DSP soud card will solve your problem.
This can happen for several reasons. I am guessing that you have the sound card and driver software installed correctly.
Many times this is caused by Windows not using the new card as the default Sound card. Since you have not mentioned what operating system you are using and didnt mention if you have an onboard sound card with the new card, take a look at the instructions on the page below. It gives instructions on how to set the new sound card as the default card.
your sound card not adjusted/inserted properly.
if insertef properly then your sound card not support your motherboard
or insert into another slot sound card may be that is not support.
2...if your sound card is built in motherboard then may be your driver is not support to sound card.tell me about your sound card company.
in your computer sound card problem. otherwise please check the control pannal in sounds and vedios.
then check the computer wheather the sound card installed or not. if the sound card not installed please installed the sound card drivers.
Linked above is the download page for all Creative Sound cards. Choose your model sound card and it will take you to a download page for drivers with all supported OS's, including XP
we lost the driver of our sound card card Trident 4DWAVE-DX. we cant locate the product in the internet.pls provide us the driver for this sound card.tnx
