Nextar MA933A MP3 Player Logo
A
Ayanna Davis Posted on Apr 13, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do u charge it and turn it on. - Nextar MA933A MP3 Player
Mike M
Level 3:
  • Nextar Master 3,349 Answers
  • Posted on Apr 13, 2014
 Mike M
Nextar Master
Level 3:
Answers
3349
Questions
0
Helped
686129
Points
16707
1helpful
3answers
After connecting the charger cord and plugging it into the wall socket, is the iPhone to be turned off or turned on?
If you turn it off, it will charge faster. I've done both. This morning my charge was very low. Then I noticed the plug became out of the socket. Try it both ways,see what happens. If you are charging with it on, have you closed all your apps? Double press the on/off button on the bottom front. Any open apps will appear half size. Place your finger on the app, and slide it UP and "OFF" the unit. Turn it off, try charging. Be sure your plugs are all the way in. If you try it turned off, the unit will briefly show your current charge, then turn itself off.
It doesnt turn on and charge
If you charge off USB and the device won't turn on you could try charging it with a wall charge as some devices need to be on to charge from USB .
Samsung sl605 wont turn on
A charging battery's light is red. If it turns green then it means it is fully charged. Since you had stored your battery for a while, try to charge it by using a battery charger to kickstart it. It should work. Whatever transpires let me know. thanks and rate this answer.
10helpful
2answers
My Coolpix S2500 wont turn on or charge. I've only used it once till the battery went flat and didn't charge it for 2 wks n now when i try to charge ti nothing happens
Easy.
Remove memory card
turn on
re-charge
shut down
re-install memory card.....
If it does not turn on with memory card removed, connect to charger and turn on
My laptop in turn on but not charging and i turn off charging
sounds like you have replaced the laptop charger for the laptop to a universal charger and not an original.
MY COBY MP3 WONT TURN ON EVEN AFTER CHARGING AND
The most common cause is a flat battery. There is a trick to charging the battery in these small mp3 players. It wont charge if it is turned on, and it won't charges if it's turned off. Here what to do...
1. plug the payer into your USB port. or wall charger
2. switch thje palyer on using the mechanical switch (on the side)
3. turn it off by either holding down the play button, or selecting "System" from the menu
4. The screen will go black and the battery will begin charging.
3helpful
Need charging instructions for Air Hogs Havoc heli. Is remote control switch to be turned on during charging? What position is channel switch in? Is Heli on/off switch set to charge? I have no...
1.Take out charging wires. 2.turn off your heli and insert charging socket into your heli's socket. 3.the charging green light will light up while charging. 4.charging complete, the green light will turn off. 5.pull out the wires and you are ready to fly. Let the heli's battery cool down for approx. 15 minutes before charging.
Unit will not turn on
Your battery is recharged when connected to your computer. Turn the player off and connect it to your computer via the USB cord. The computer must be turned on. Initial charge should be for 10 hours with subsequent charges 3 to 4 hours for a full charge. A quick charge of 1-1/2 hours will give you a 70 percent charge. A fully charged battery will last up to 15 hours under normal use.
3helpful
13answers
Audiophase KZ111 MP3 players won't charge
One thing that I have found that works is that you slide the switch to the "ON" position, but don't press play to turn it on all the way. Do this BEFORE plugging it into your computer. I have had the mp3 player fro a year or two and I have charged it about 15-20 times.
Top Nextar Audio Players & Recorders Experts
ADMIN Andrew
ADMIN Andrew
 Grubhead
Grubhead
Vinho Xie
Vinho Xie
Are you a Nextar Audio Player and Recorder Expert? Answer questions, earn points and help others
