SOURCE: Heat Pump or not???
This is an air conditioner. Based on the numbers you gave me, this is what I come up with. Thanks.
C= Split system
KL= Air conditioner
30= 2.5 ton
1= 208 230 v
D= Revision
SOURCE: need to know unit size
ckl60 5 ton about a 2003 model on most ac heat pumps the model number reflects the ton sized by 12000 btus per ton also as for the indoor unit cfm rating 400 cfm per ton
SOURCE: I need a blower motor
If you have it removed already take to a motor shop and they can cross ref it for you.
SOURCE: looking for freon capacity for 5 ton goodman
check low side which is the bigger of the two, make sure you tighten the hose good. your reading should be 65 psig.If not add refrigerant/r22 . if r410a 110 to 115.
SOURCE: when was the goodman model CKL36-LL serical number 0504211625 produced
The first two digits of the serial number are the year (2005) and second pair of digits are the month (April).
