SOURCE: My ten year old Health
First be sure there is power at the outlet. Check that the power switch is on, and the circuit breaker is not tripped (beside the power cord).
Remove the hood and inspect the wiring. (unplug the machine first). Ensure that all connectors are tight and none are burnt. At this point if all appears to be OK, look for lighted LEDs on the power PCB. If all is dark, replace the power PCB ( approx $100). If the LEDs are lit, you may require a console, or the safety key switch might be defective. To check it, the console must be removed and the console base removed. Inspect and test the micro switch.
The console is no longer available.
