A
Anonymous Posted on Apr 12, 2014
Magenta horizontal stripes on paper (approx 11 per page), what can I do to resolve?
On every sheet op paper I have approx 11 horizontal magenta stripes starting from left and fading to the right for about 1 inch. Who knows what I can do about it?
5 Related Answers
Anonymous
  • 55 Answers
  • Posted on Oct 24, 2007
SOURCE: why do all pages print onto one page when i hit the print button in a multipage document
I guess you are using word. In that case the default driver you use and comes standard with windows is flawed. Download a new one from HP.
Anonymous
  • 5 Answers
  • Posted on Feb 29, 2008
SOURCE: Colors are uneven, too much green on the right side and too much red on the left
Same problem with my HP Color (Colour) LaserJet 2605dn. I took apart the printer and found the mirrors inside the optic box all covered in dust. A clean with a cotton bud (Q-Tip) solved the problem.
I took lots of photos of my solution and put them on my website, if you're interested. Don Thompson's pdf file (see other posting here) is also a good source of info on the problem and solution.
My photos & cleaning steps:
http://tinyurl.com/yoq4mq
-- which just redirects you to this longer URL:
http://blog.reeves-hall.net/fixing-washed-out-colour-on-hp-color-laserjet-2605/
Anonymous
  • 25 Answers
  • Posted on Aug 14, 2008
SOURCE: printer prints a line across the paper around three inch from the left hand side of the page.
Check your Toner Carts.
Is the line a certain color?
Black perhaps?
Lift the door of the toner cart.
If you see a streak on your toner drum, you will see a streak on your paperwork.
Look at your fuser as well.
Is there a problem with the big orange roller?
BEWARE! Don't touch the fuser roller its EXTREMELY HOT!
Let the printer cool down before inspecting.
Anonymous
  • Posted on May 11, 2009
SOURCE: Faded red / pink on HP Color Laserjet 2605
you have to clean the image mirrors you can find a how to guide on hp's web site titled "fading red tones on color laserjet2600' process takes about 30mins to do.
JaxPlanet
Jax Planet
  • 923 Answers
  • Posted on Jun 06, 2009
SOURCE: Problem printing multiple pages on one sheet!
The problem is the PCL5 driver.
Replace it with a PCL6 driver.
Apparently, Microsoft issued an update that broke PCL5 drivers.
Perhaps they were trying to save paper. LOL!
2helpful
2answers
Ricoh Aficio 2232c leaving stripes on backside
AS I understand you have black stripes on the back side of the print, so if this is the case, the Image transfer cleaning blade need to be replaced. Part number is: Genuine Ricoh Aficio 2238C Transfer Belt Cleaning Blade Ricoh AD04-1081, AD041081
Need to turn a 1 page 11 x 17 into a 2 page 81/2 by 11 doc
  1. Open the Page Setup dialog by double-clicking the horizontal ruler or by clicking the dialog launcher (tiny arrow) in the bottom right corner of the Page Setup group on the Layout tab.
  2. On the Paper tab, make sure the paper size is set to 11x17.
  3. On the Margins tab, for "Multiple pages," select "Book fold."
  4. Make sure the orientation is set to Landscape.
  5. Click OK.
Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us For
Techsupport Printer
How can I found out the stats on a Canon NP 6551 (ie total pages, etc...)?
NP6560 Main Specifications
Main Unit
Type: Console
Platen: Stationary
Photoconductive material: Amorphous Silicon
Copying system: Electrostatic transfer system
Developing system: Toner projection system
Fixing system: Heat roller system
Acceptable copy stock: Paper drawer:17 to 24-lb bond (64 to 90 g/m2); plain paper
Stack bypass:17-lb bond to 110-lb index (64 to 200 g/m2); plain paper
(However, Keep in mind that the paper weight that can be used varies
depending on the type of the Sorter being used.
SADF tray : transparencies and labels
Acceptable originals: Sheets, books, and three-dimensional objects (up to 4.4-lb or 2 kg)
Maximum original size: 11" x 17"
Copy sizes: Paper drawer: STMT, STMTR, LTR, LTRR, LGL, and 11" x 17"
Stack bypass: 4 1/8" x 5 7/8" (horizontal placement) to 11" x 17"
Non-image areas: Leading edge: 1/4" (4.5 mm)
Left and right side: 1/16" (3 mm)
Trailing edge: 1/16" (2 mm)
Warm-up time: Approx. 6 minutes (at temp. of 68°F)
First copy time: Max. 2.8 seconds
[LTR size, direct copying, Manual Exposure Control, Drawer 1 (top
drawer) selected 1→1-sided mode]
Copy speed: Direct (100%) LTR 60 cpm
65 cpm (Accelerated mode)
LTRR 49 cpm
11"X 17" 30 cpm
LGL 40 cpm
STMT 60 cpm
STMTR 60 cpm
Reduction 11"x 17" → STMT 56 cpm (50%)
11"x 17" → LTR 48 cpm (64%)
11"x 17" → LGL 40 cpm (73%)
11"x 15" → LTR 48 cpm (73%)
LGL → LTR 49 cpm (78%)
Enlargement LGL → 11"x 17" 30 cpm (121%)
LTR → 11"x 17" 30 cpm (129%)
STMT → 11"x 17" 29 cpm (200%)
Magnification: Direct 1:1.000
Reduction 1:0.500 (11" x 17"→STMT)
1:0.647 (11" x 17"→LTR)
1:0.733 (11" x 17"→LGL/11" x 15"→LTR)
1:0.786 (LGL→LTR)
Enlargement 1:1.214 (LGL→11" x 17")
1:1.294 (LTR→11" x 17")
1:2.000 (STMT→11" x 17")
Zoom 1:0.490-1:2.040
7-8
Paper feeding system: Drawer 1, 2 (1,500 sheets x 2)
Drawer 3, 4 (550 sheets x 2)
Stack bypass (50 sheets; stack approx. 1/4" high)
Multiple copies: 1-999
Power source: 120 V, 60 Hz
Max. power consumption: Less than 2.0 kW
Dimensions (H x W x D): 46" x 25 3/8" x 28 1/2"
(1169 x 643 x 725 mm)
Installation Space (W x D): 40 5/8" x 28 1/2"
(1030 x 725 mm)
50 3/8" x 28 1/2" (1280 x 725 mm)
[With copy tray (option) attached and stack bypass auxiliary tray extended]
Weight: Approx. 462 lb (210 kg)
RDF (Standard equipment)
Originals: STMT to 11" x 17" size (STMT-size cannot be placed horizontally.)
Original tray: LTR 15-lb to 110-lb bond (52 to 200 g/m2)
11" x 17", LGL, LTRR, or STMT
15-lb to 32-lb bond (52 to 128 g/m2)
SADF tray: 11" x 17" to STMT
11-lb to 110-lb bond (38 to 200 g/m2)
Max. power consumption: 120 W
Original tray capacity: Original tray: 11" x 17" or LGL
50 sheets (20-lb bond or 80g/m2)
LTR, LTRR, or STMT
100 sheets (20-lb bond or 80g/m2)
1 sheet
Original replacement speed: 60 sheets/minute (LTR, horizontally placed)
Power supply: 24 V (supplied from main unit)
Dimensions (H x W x D): 6 7/8" x 25 3/8" x 21 1/4"
(174 x 643 x 539 mm)
Weight: Approx. 56.3 lb (25.5 kg)
These specifications are subject to change without notice.
8-1
ar
Energy Saver
Stop
Guide
Additional Functions
Start
Display Contrast
ii
Enter a ID number with the Number ( 1 - 0 )
keys.
MEMO: ? If you make a mistake entering an ID number, press
the C
Clear
key. Then, enter the ID number again.
? You cannot enter two identical ID numbers.
? If you enter and store "000000" in place of a current
ID number, that ID number is canceled.
? You can store up to 1,000 ID numbers.
Press the [OK] key.
If you want to store another ID number, repeat
steps 3 to 5.
5
After entering all the ID numbers to be stored,
press the ID key. The display returns to the ID
entry screen.
6
Canceling the ID Mode: Clearing All ID Numbers
If you clear all the ID numbers then you can make copies without having to enter an ID
number.
Press the Additional Functions , ID , Stop , and Additional Functions keys in that
1 order.
Clear
Guide
Interrupt
Reset
Clear
Energy Saver
Stop
Guide
Start
Display Contrast
iii
Press the [OK] key.
MEMO: ? If you want to stop all the ID#s from being cleared,
press the [C] key.
Press the [CLEAR ALL ID#s] key.
Press the [STORE USER ID#] key, then press
the [OK] key.
All the ID#s are cleared.
If you press the [OK] key, you will return to the
Standard mode.
MEMO: ? Storing all the ID#s under "000000" will also clear all
the ID#s.
iv
In the ID mode, the copier keeps track of the copy quantity made under each ID number (up to
999,999). You can view the copy total for each ID number in the touch panel display.
1 order.
After pressing the [COPY TOTALS] key, press
2 the [OK] key.
Press the [?] or [?] key to check the copy totals
for a department. The copy totals can also be
displayed by entering the department number.
Press the Number keys ( 1 - 0 ) for a four digit
department number and it appears at the top of
the display. When you finish checking the copy
totals, press the [OK] key.
Copy Totals (Check Totals)
The following procedure describes how to clear the copy totals for all ID numbers to zero.
Copy Totals (Clear All Totals)
1 order.
Reset
Clear
Energy Saver
Stop
Guide
Start
Display Contrast
Reset
Clear
Energy Saver
Stop
Guide
Start
Display Contrast
v
2 the [OK] key.
Press the [CLEAR ALL TOTALS] key. 3
Press the [OK] key.
MEMO: ? To cancel clearing all totals, press the [C] key. 4
The copy totals for all ID numbers are cleared to
zero. If you press the [OK] key the display
requesting the entry of an ID number appears.
MEMO: ? You cannot clear the copy totals for ID numbers
individually.
Right side of every page has pink strip down page
Either your magenta cartridge is leaking out of the right corner or you have a defective magenta drum.
(maybe it got scratched when changing the cartridge?) If it's the magenta drum, you have to replace all the drums since they come in one unit. OEM part only.
Pages printing blank
Resolving white, light lines or streaks (eliminate light stripes)
From the printer, print the Troubleshooting Print Quality Pages.
With Troubleshooting highlighted, press the OK button.
Scroll to Print Quality Problems by pressing the Up or Down Arrow button. Press OK.
Scroll to Troubleshooting Print Quality Page. Press OK.
Evaluate the Light Stripes Test page for missing printhead jets (missing cyan, magenta, yellow or black color bars).
Clean the maintenance unit's wiper blade and empty the waste tray. A dirty maintenance drawer wiper blade can cause white lines and weak or missing printhead jets. Using a clean lint-free cloth or a paper coffee filter, gently clean the blade with a wiping motion across the entire length of the wiper blade.
Paper Result
if you use fast draft than you can take approx 150 else in any other prefrences it will give upto 120 pages per cartridge. so use proper setting as per the requirement.
Phaser 8560 magenta ink not transfering to paper
Hi jbasset285: Your printhead may be bad do to third party ink.
Try these steps first.
Diagnosing Print-Quality Problems
The Troubleshooting Print-Quality Page provides a good overview of the most
common print quality problems. To print the Troubleshooting Print-Quality Page,
follow these steps:
1. From the Control Panel, scroll to Troubleshooting, then press OK.
2. Scroll to Print Quality Problems, then press OK.
3. Scroll to Troubleshooting Print Quality Page, then press OK.
The Troubleshooting Print Quality Page includes instructions for printing the
Eliminate Light Stripes test print. These instructions are also provided on the next
page of this manual. The Eliminate Light Stripes test print indicates individual weak
or missing jets or an obstruction in the imaging path that affects a vertical band down
the entire page. Also, you may see color variation from jet to jet on the Eliminate
Light Stripes test print. Some variation is normal, occasionally occurs, and usually
self-corrects within a few printed pages. If a print-quality problem is not resolved
with the information provided in the Diagnosing Print-Quality
CLP-500 vertical streaks & a horizontal line with blotches appearing randomly
I've refilled the toner cartridges a few times now and never had a problem with vertical streaks until recently. I refilled both the cyan and magenta and when I ran the test page I had dark vertical streaks on both sides. I fiddled around cleaning things, running cleaning paper through, changing reset resistors but to no avail so eventually decided to buy a replacement refurbished cyan cartridge since the streaks looked mainly blue and bingo... well almost now I just have very light magenta streaks. The issue is obvious when I compared the old and new cartridge, the replacement toner is a much duller cyan and is of the wrong consistency since once it's been in the printer everything gets covered in it which is why I think it causes the banding to occur. I'm just trying to work out now whether to try refilling the magenta again (v. messy) or just go for another refurbished cartridge (£34).
k24674
Grand Canyon Tech
Grand Canyon Tech
