HP LaserJet 3050 Printer Logo
A
Anonymous Posted on Apr 12, 2014
Reset chip hp 3050 - HP LaserJet 3050 Printer
How to reset expired hp 02 cartridge
I'm not sure what you mean by "reset" and whether you are speaking of ink jet or laser cartridges. From my experience all HP laser cartridges have a small chip (with a little circuitry) that counts down your pages and when it decides your cartridge is out of toner you cannot "reset" that chip, you can only replace it, so like when you refill the cartridge. Some of the HP laser printers let you override these toner level chips (my HP 1518ni does) but in many laser printers you are stuck when the chip counts down to '0' pages. Some printers will run if you remove the chip from the cartridge but from my experience most will not.
Ink jet cartridges are somewhat similar but I gave up on ink jet printers several years ago. I know for some brands (Epson?) you can buy a small tool that somehow resets the cartridge chip (so if you refill cartridges yourself); possibly there is something similar for HP ink jet cartridges.
Reset chip
no need to reset chip on hp 1010 laser printer. there are not any chip on printer Cartridge.
1helpful
2answers
HP 4530s BIOS admin password
Here is a post about how to hack hp password with Windows Password Recovery Tool, you need it. Don't waste time at unnecessary help.
http://www.windowspasswordsrecovery.com/hack-hp-computer.htm
1helpful
Can i refill officejet j5780
Yes it will not work unless you can reset the chip.
This WEB site can assist you in resetting the chip in the cartridge.
http://www.misterinkjet.com/hpreset.htm
Reset hp toner
We cannot reset the chip through printer or system. Now a days chip re-setters are available & memory chips also available in the market, choose better one.
1helpful
I have just replaced my toner on my HP M2727 nf printer, how do I reset the page count only?
There is no resettable page count on this printer. If you are referring to the counter for the toner level, that is reset by a chip on the cartridge. That chip only works once and if you are using a refilled cartrige that chip should have been replaced. If you refilled it yourself you will need to check on Ebay to find a replacement chip. If you bought a refilled from someone else, take it back and get them to change it. If you bought an OEM HP cartridge and it does not reset the count then call HP as the guarantee their cartridges.
How to reset hP 2600 colour printer chip
When you refill an HP color laser cartridge you need to replace the SmartChip, as I do not believe that there is any way to reset the chip. Any reputable seller of toner would include the chip with the toner order. The are for sale on Ebay
HP Officejet 6500 does not recognize refilled ink cartridges and will not print. Help Please.
If your cartridges have a chip on them the chip might need to be reset before the printer will recognise that the cartridge is full, this is how printer manufacturers make sure people buy genuine products, you can get aftermarket kits to reset your chips from places like ebay.
This machine ran out of toner today, but didn't give a local notification that it was low. I have tried to find the setting to enable this notification via the printer's web page, but am unable to find it....
Thank you for contacting FixYa with your printer inquiry.
HP toner cartridges for this printer have an embedded chip built into the cartridge that prompts "Low Toner" message locally and will broadcast through its WEB server. Non HP Toner Cartridges or Refilled HP Toner Cartridges will no longer have the chip enabled to generate this message. You can continue to print but the toner level status will not be generated.
Solutions; Purchase new HP Toner cartridge's from reliable source.
Try a third party replacement chip"
http://cgi.ebay.co.uk/HP-LaserJet-P4015-P4015n-dn-Toner-Reset-Chip-CC364X-64X-/310239780829
http://www.octopus-office.de/en/shop/details/c/toner-powder-hp-p-4014-4015-4515/p/reset-chip-hp-p-4014-4015-4515-black-toner-chip/
Hope this helps. Please keep us updated and remember to rate this answer.
4answers
How do i install a toner chip on my hp Cp2025
TONER CHIP on CP2025 printer:
This resource may help
http://resources.lasertekservices.com/hp-smart-chips-overriding-this-lockout-mechanism-with-reset-chips/
Gives types of chips to use, sales in USA, and certain things to take note of.
The toner reset chip replaces the original HP ID chip and is designed to be used only on refilled HP cartridges.
It is not recommended to force toner cartridges to run on empty, as this can cause damage to both the printer and the toner cartridge.
The reset chips are dedicated to one color only, so that user can not swap toners.
As for actual physical installation, just push the new ID chip in until it clicks into place. The correctly manufactured ones should be a snug fit.
I have seen techs using a drop of contact glue behind the chip-board to secure it.
Copper pads face outwards towards matching printer pins.
See photo for polarity 'square' pad.
My printer is Samsung, not HP, so your toner cartridge may be a different shape.
k24674
Grand Canyon Tech
Grand Canyon Tech
