I have a monitor and was turning up the brightness at the button and seemed to have pressed something because the screen was a lot bigger than it is just now. I know that you can make the writing bigger on google and other apps but I don't want to have to keep changing the size counstently.
SOURCE: problem with samtron 56v 15" monitor
IT IS REULATION COMPLIANT PLEASE CHANGE THE 7805REGULATOR IC NEAR THE MEMORY IC
SOURCE: dell m782 Brightness control???
Brightness is adjusted by using the 2 buttons on the left side of the front.
See instructions here:
http://support.dell.com/support/edocs/monitors/m782/En/controls.htm
SOURCE: Monitor will not turn off and keeps flashing the words Auto processing
unplugged/plugged power cable on monitor. problem went away
SOURCE: probably not only because I found several forums
Check out this link below for a PDF manual for your monitor. You can also update your drivers. There is a support here also. Just copy and paste into your browser.
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=05020100&prd_mdl_cd=&prd_mdl_name=720N
Hope this helps. Let me know if I can help you with anything else.
JimmyC
Testimonial: "Thank you very much!"
it is not a bad rom. if it was a rom it would constantly act up but it only acts up upon overheating. The solution is difficult but if you open the monitor you can find all of the heatsinks take them of and replace them with bigger ones. or have a fan blowing on it at all time it is active i added bigger heatsinks to my emachine le1799 and it solved this problem of pulling up menu and changing setting by itself and the lack of the ability to turn power of.
