Question about HP No 60 Black Ink Cartridge
HP black ink cartridge and HP deskjet pritner 1055
My HP 60 black print cartridge prints black shadows (perhaps smudge) that cannot read at all while the color one HP 61 is ok and clear. I can't tell if it is the ink (I refill at Costco once), or the printhead that is damaged. I aligned, cleaned the heads, changed the papers, etc. The black ink prints the same while the color is fine. I sought advice from a computer clinic and the guy said he is not familiar with printers. HE suggested the salesman and the only thing he said was to buy a new one. Other stores(including stores that sell ink and printers/calculators) say they don't know but better buy a new printer. I was wondering if it is just the cartridge. IF I buy a new cartridge, would it fix it? The guy who sells new print cartridges says second hand refills are not recommended because he said the ink could explode and you end up with a mess to clean. I read somewhere else on the web that this is not true. Can you tell me from looking at the scanned paper if indeed the problem is the cartridge ink refilled from Costco or my printer is indeed ready for retirement. I have a HP deskjet 1055 which I read online that it should have been a good reliable model for basic printing and should have lasted for 3+years. While I bought it over 4 years, I didn't open it right away but started using it since 2013.
  • HP Master
  • 20,706 Answers
End of life.
buy a real laser jet like hp1102w.
or better
inkjets stink, imo
Posted on Mar 10, 2017
SOURCE:
  • 31 Answers
SOURCE: Cleaning the print head on my HP5440 printer?
Try cleaning the head of the cartrige with alcohol and a Q-tip, if this doesn't help you may have to buy a new one. Cartriges can dry up if they haven't been used for a while. Even though you refilled it, there could be some dry ink stuck in the head. Hold the Qtip with alcohol on the head for a bit and let it dry, reinstall it and then try printing again.
Posted on Nov 08, 2007
SOURCE: I HAVE A HP DESKJET 940C PRINTER. BLACK PRINTING PROBLEMS.
I GOT A CLARIFICATION REQUEST AND I SENT FURTHER INFORMATION BUT AS OF YET I HAVE NOT RECIEVED ANY FURTHER INFORMATION BACK FROM "KEEPITSIMPLE".
Posted on Jan 28, 2009
Ajkill
  • 2035 Answers
SOURCE: refilled cartridge not printing
Try to cartridge manually ,please follow the instructions :
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Posted on Feb 17, 2009
  • 11800 Answers
SOURCE: I ran out of ink
You have used either the wrong type of ink or you refilled the cartridges incorrectly - the result was that the ink spilled over on the cartridge contacts and messed them up.
Take the cartridges out, unplug the printer and using a damp q-tip gently and thoroughly clean all the contacts on the carriage. Then buy a new set of remanufactured cartridges like
http://www.123inkcartridges.ca/hp-ink-cartridges/Deskjet-F340.html
put them in and run several cleaning and alignment tests. That should be enough to fix it.
Posted on Oct 01, 2010
  • 13434 Answers
SOURCE: I have an HP office
Hello.
Depends if you are printing pictures from either memory card or directly from camera or from the computer.
If you are printing from the computer, you need to go to start -> printers and faxes -> right click printer, printing preferences or such and find paper size setting.
If you are printing from camera, memory card that is connected to the printer directly then you need to see the paper size settings on the machine.
Posted on Oct 06, 2010
Why does my HP Deskjet F4280 Show an E in the Start/Copy screen??
Regarding your recent inquiry about the HP 60 cartridge error message ("E in display window") and inability to print with your HP Deskjet F4280 printer, this type of error is normally associated to an electrical connection issue between the printer and the cartridge, or more likely, an internal micro-electronic failure inside the cartridge itself (please note that it is very rare for both ink cartridges to electrically fail at the same time). An electronic failure of the cartridge would be unrelated to the ink cartridge refill process; these same failures can (and frequently do) occur with brand new ink cartridges.* To help identify the root cause, please run the 'Tap 41' cartridge's electrical / diagnostic tests below (refer to B. and C), this will identify which ink cartridge is causing the issue:
NOTE: Unfortunately, alignment pages and internal self test prints will usually print Ok even if the cartridge is internally electrically damaged. Do not use these test pages as a proxy for determining whether a cartridge is good or bad, only the 'Tap 41/43' diagnostic test report can yield this information.
As a temporary workaround, or if you are unable to determine which cartridge is causing the issue, remove one of the ink cartridges from the printer....this might place the printer into the 'single cartridge printer mode'....print jobs may then be executed from the computer (only):
An internal electrical failure of a cartridge can be confirmed by performing the following corrective/diagnostic steps:
A.Ensure BOTH carriage/flex cables and BOTH ink cartridge contacts are thoroughly clean before proceeding: http://inkjet411.com/?page_id=1519
B.Validate the cartridge's electrical health by running the 'Tap 41' diagnostics test. Refer to DIAGNOSTIC TAP 41 video procedure at the following link on how to activate and read the service test:
http://inkjet411.com/?page_id=440 (HP 60 - Deskjet F2400/F4400/F4500 models)
    1.While holding the Power button, press Cancel (X) button 4 times, then press the Color Copy button once.
    2.Release the Power button.
    3.The 'Tap 41' diagnostic test print should print.
    http://inkjet411.com/?page_id=444 (HP 60 - Deskjet F4200 model)
      1.While holding the Power button, press Cancel (X) button 4 times, then press the 'Resume' button once.
        --- Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 60/60XL color cartridge should display 1248 good nozzles, while a good HP 60/60XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the printout.
        ---- If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
For any additional questions please contact us directly: Inkjet411help@gmail.com
To purchase the lowest cost ink cartridges available in the USA (remanufactured in the USA) please visit: http://www.inkplicity.com/
-Thank you
Aug 14, 2014 | HP DeskJet F4280 All In One Printer InkJet
Hp 4480 how do you unpause it
The HP F4480 likely has a malfunctioning ink cartridge which is causing the printer hang (i.e. internal micro-electronics damage inside the HP 60 color or black ink cartridge). You can verify the electrical condition of both HP 60 ink cartridges by activating the Tap 41 diagnostic test report (see video here for complete instructions):
    For additional support please visit http://www.inkjet411.com
    -Thank you
Dec 09, 2013 | HP F4480 All-In-One Printer
Can I print on my hp 6122 deskjet with only a black ink cartridge? I have no color ink.
Yes, all HP Deskjet printer models feature a 'single cartridge print mode'. Just remove the cartridge you don't wish to print with; the printer will automatically revert into either greyscale printing (if color cartridge remains installed) or black only printing (if the black cartridge remains installed). However, if the installed ink cartridge is electrically damaged/defective the printer will display an alert message; it will need to be replaced with a new cartridge.
For more information on the use of refilled ink cartridges or advanced HP printer problem diagnosis please visit Inkjet411:
Sep 03, 2013 | HP Office Equipment & Supplies
Large ink spill. Printer no longer recognized new black cartridge.
You can perform the Tap 41 Cartridge Health Diagnostics Test: [applies to HP Deskjet 6800/6900/9800]
http://inkjet411.com/?page_id=1741 (refer to 2nd video to understand how to read the printed pattern)
1. With printer power on, press and hold the POWER button.
2. Press the Cancel (X) button four (4) times.
3. Press the RESUME button (Down Arrow) once.
4. Release the POWER button.
5. The Diagnostic Test Report should print.
--- A good HP 93/95/97/99 color cartridge should display 600 good nozzles, while a good HP 92/94/96/98 black ink cartridge should show 672 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the printout: http://inkjet411.com/?page_id=1741
---- If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink (special "ink back-up mode").
For information on North American ink refill services at a major retailer near you (should you wish to save ~50% on ink costs), general printing problem resolutions or advanced HP printer diagnosis procedures (advanced cartridge diagnostic tests/cartridge error bypass & printer reset methods, etc.), please visit Inkjet411: http://www.inkjet411.com
Aug 27, 2013 | HP Deskjet 6988 Inkjet Printer - Color -...
Have hp d1430 printer, I only use the color print cartridge, the printer will print color but will no print normal black lettering, have tried two different hP22 cartridges. Is the printer done for?
YOU SHOULD USE HP 21 BLACK INK CARTRIDGE FOR BLACK PRINTING.IF YOU USE 22 COLOUR CARTRIDGE YOU WILL GET ONLY GREAY PRINTING ONLY.I AM RIGHT?IF YOU USE COLOUR CARTRIDGES MAY YOU WILL GET MONEY LOSE. BECOS IT WILL FINISH EARLY.BLACK INK COST IS LESSTHAN COLOUR INK CARTRIDGES. SO YOU SHOULD BUY BLACK CARTRIDGE FOR REAL BLACK PRINTING.
Jun 29, 2011 | HP Deskjet D1430 InkJet Printer
How to change ink in HP Deskjet F480 printer???
  • Check the ink levels by opening the HP Solution Center. Click on "Settings." Click on "Toolbox." Click on "Services." Click on "Service this device." Click on "Estimated Ink Levels." A graphic will appear showing the estimated ink level in each cartridge.
  • 2 Verify that the unit is on. Open the print cartridge door allowing the print carriage to move to the far right side of the unit. Once the print carriage has stopped, lightly press down on a print cartridge to release it. Pull the print cartridge toward you out of its slot. To replace the tri-color print cartridge, remove the print cartridge from the slot on the left. To replace the black or photo print cartridge, remove the print cartridge from the slot on the right. Place the cartridge in a plastic bag as it may still contain some residual ink and may leak.
  • 3 Remove the new print cartridge from its packaging. Remove the plastic tape by using the pull tab, being careful to not touch the copper-colored contacts or the ink nozzles under tape.
  • 4 Slide the new print cartridge forward into the empty slot. Gently push the upper part of the print cartridge until it clicks into place. The tri-color print cartridge fits into the left slot. The black or photo print cartridge fits into the right slot.
  • 5 Close the print cartridge door. If the print cartridge alignment sheet prints, load it on the left front corner of the scanner glass with the top of the page to the left. Verify that there is plain paper loaded in the input tray, and then press the "Scan" button to align the printer.
  • Read more: How to Replace an Ink Cartridge in an HP Deskjet F340 ' eHow.com http://www.ehow.com/how_2303716_replace-ink-cartridge-hp-deskjet.html#ixzz16MAooFTf
    I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
    Nov 26, 2010 | HP DeskJet F380 All-In-One Printer
    Smudged printing. Ink cartridge just replaced.
    This is a laser printer and does not have a print head to be cleaned. Fortunately it does have a laser cartridge that can easily be replaced and solve all of your problems : ) The replacement cartridge is a HP Q2613A or the high capacity HP Q2613X. Your local Cartridge World should have a high quality refilled cartridge that will treat you very well and save you money.
    Jan 03, 2010 | HP LaserJet 1300 Printer
    Wont print in color only black and white
    wrong cartridge or needs cleaning the contacs
    Dec 15, 2009 | HP DeskJet D2560 InkJet Printer
    HP Deskjet 6940 not printing after replacing ink cartridge
    My HP Deskjet 6940 is not printing. The color (left) low ink light is dark and the black (right) low ink light is flashing. I replaced the black ink cartridge with a new one but the low ink light continues to flash. No tears/rips in the circuit strip and all the copper leads appear to be connected
    Sep 29, 2008 | HP Deskjet 6940 InkJet Printer
    HP No 60 Black Ink Cartridge Logo
    139 people viewed this question
    Top HP Computers & Internet Experts
    Ekse
    Thomas F. Schneider
    Alun Cox
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
