Ortho 1pt Rose Pride Disease Control Concentrate 0347060 Logo
A
Al Mock Posted on Apr 12, 2014
Where do I find expiration date on Orthodox Rose pride disease control
Jason Pincomb
Level 1:
New Friend:
  • Contributor 18 Answers
  • Posted on Sep 05, 2014
Jason Pincomb
Contributor
Level 1:
New Friend:
Answers
18
Questions
Helped
12764
Points
20
The best way to get that information is to call the number on the bottle and give them the lot number located on the bottle.
2answers
Can you get a service manual for the Pride Zero Turn 10?
To access the controllers on a Pride Zero Turn 10 scooter, you typically need to remove the body shroud. Here's a general guide based on similar models: 1. Lift off the body shroud
. 2. Turn off the controller before proceeding
. 3. Loosen and remove the nuts to take off the body shroud
. For specific instructions tailored to the Zero Turn 10 model, it's recommended to consult the official owner's manual from Pride Mobility Products
. Unfortunately, a service manual for this specific model may not be readily available online. If you encounter difficulties, consider reaching out to Pride Mobility or an authorized service provider for assistance.
What diseases affect knock out roses?
Hello, Samuel -
Diseases which threaten the Knockout Rose:
- Black Spot Fungus
- Botrytis Blight (Black Mold)
- Powdery Mildew
- Rust
- Stem Canker
- Rose Rosette Disease (RRD)
Read about the diseases here (plus click or tap on the links in the article):
https://www.gardeningknowhow.com/ornamental/flowers/knockout-roses/knockout-rose-diseases.htm
Pests which can negatively affect Knockout Roses are listed here:
http://homeguides.sfgate.com/eating-knock-out-roses-95044.html
Best wishes.
May 27, 2018 • Garden
1helpful
What dose red or yellow blinking lights on my jazzy pride electric power chair mean /
  1. VR2/VSI DIAGNOSTIC FLASH CODES
# OF LEDS
CODE
CAUSE
POSSIBLE SOLUTION
One red LED
Low battery voltage
Charge batteries
Two red LEDs
Left motor open
Make sure left motor is plugged into controller.
Three red LEDs
Left motor wiring fault
Contact your authorized Pride Provider.
Three red LEDs One yellow LED
Right motor open
Make sure right motor is plugged into controller.
Three red LEDs Two yellow LEDs
5
Right motor wiring fault
Three red LEDs Three yellow LEDs
6
Inhibit active
Three red LEDs Four yellow LEDs
7
Joystick error
Three red LEDs Four yellow LEDs One green LED
8
Controller error
Three red LEDs Four yellow LEDs Two green LEDs
9
Brake fault
Make sure both motors are plugged into controller.
Three red LEDs Four yellow LEDs Three green LEDs
10
High battery voltage
What if the speed LEDs on the VR2/VSI begin to flash?
  • Determine if the battery charger is connected to the power base. When the battery charger is connected to the power base, a charger inhibit feature keeps the power chair from driving. This is indicated by the VR2/VSI speed
    LED(s) flashing.
  • Determine if the charger harness fuse has blown. A blown charger fuse can cause the charger inhibit to
    activate.
  • Determine if all controller connections are plugged into the power base properly. If the 3-pin charger
    inhibit connector is not plugged in properly, then the charger inhibit feature will activate.
My status light blinks 7 times on my pride scooter how do I fix it
Hi 7 flashes ( SPEED POT ERROR ) possible speed control pot ::: wig-wag. control lever ,is ,faulty or it's possible the computer (CONTROL BOX ,) is Faulty...Get in touch with pride mobility ,..www.pridemobility.com.au .. Cheers
2answers
Controller flashes 9 times what does that mean
Basic Troubleshooting Instructions - Pride Mobility Products
www.pridemobility.com > Resource Center
Pride MobilityINFINFB2468 Jazzy 614/Jazzy 614HD with Dynamic Controller Troubleshooting ... LiftChairs. INFINFB2061 Basic Troubleshooting Instructions: Lift Chairs ...
Pride Mobility Products Corp. - Product Owners Manuals ...
Pride MobilityHelp Me Choose · Where to Buy · Request to Be Contacted · View all Models. Pride Mobility Scooters ... Power Chair Consumer Safety Guide .... Version / Date. Flash. C 01/04. Pride LX Series. C 05/08. Z-11. B 07/04. Manual Wheelchair ... Travel Scooter Throttle Control Lever Operation Product Insert ... Victory 9/Victory 10 ...
Troubleshooting / Repairs Mobility Scooter, Power ...
1helpful
HOW MANY OHMS SHOULD GO THRU PRIDE CELEBRITY X CONTROL ?
I have a Pride Legend XL. I tried to get the wiring diagram, but
Pride USA would not give it to me.
They told me to call the dealer instead. I had a problem with reverse throttle creep, where the brake would not engage and it kept rolling back on me.
Had to call the local dealer to do the intial trouble shooting
(who knew exactly what the problem was) to the forward reverse throttle control pot.. I was able to order the throttle pot and replace it myself.
The problem is that Pride uses some potted modules in the tiller
and the control area, although you can find pretty much
all the parts for Pride from monsterscooterparts.com,
they don't have the wiring diagram for mine either.
I am disappointed in Pride, who want to keep their
service manual with the wiring diagram a big secret from
the owners and only the dealers have it.
Need parts breakdown pride go go 3 whell manf date 10/2002
Pride website has them but you have to be a dealer to access them and I'm affraid you will be very lucky to get a dealer to print one off or send you one via e-mail as it is obviously not good business practice, as you might be able to source the part you require elsewhere. Pride as a company would also not look at this very favourably and MIGHT even stop a dealers account for supplying such information. Sorry!
Top Ortho Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an Ortho Home Expert? Answer questions, earn points and help others
