Carrier 36KCARMS Air Conditioner Logo
Posted on Jun 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My carrier A/C turns off by itself but the light blinks
I would turn on my air conditioner, it runs for a few minutes but it turn off by itself and a green light keeps on blinking. I tried turning it back on but nothing happened except for the green light blinking. What could be the problem? By the way, my ac is carrier.
Anonymous
Level 1:
New Friend:
  • Contributor 5 Answers
  • Posted on Aug 06, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
5
Questions
0
Helped
31351
Points
14
Switch OFF the circuit breaker of ac, after 5 seconds. Switched ON the circuit breaker. If this will appear again try to check the wiring connection of ac.
Johanan Murphy
Level 2:
New Friend:
  • Expert 63 Answers
  • Posted on Aug 13, 2011
Johanan Murphy
Expert
Level 2:
New Friend:
Answers
63
Questions
Helped
43732
Points
133
The problem is the electronic sensors that senses the coil and air temperature
Anonymous
Level 2:
Sniper:
  • Expert 81 Answers
  • Posted on Jul 16, 2009
Anonymous
Expert
Level 2:
Sniper:
Answers
81
Questions
0
Helped
144946
Points
276
After reading the Carrier Manual, the light flashes indicating that the unit needs to be sericed.
Mat
Anonymous
Level 3:
  • Master 614 Answers
  • Posted on Jun 18, 2009
Anonymous
Master
Level 3:
Answers
614
Questions
0
Helped
274379
Points
1717
Could be aboard. On Carrier it is good to call service tech. Ask for free quote. That way you know the cost upfront. Rus
  • 1 more comment
  • CarrierTech Feb 19, 2011
    The Carrier unit is locking out on a Fault amount of flashes indicates fault but this can be starting point for fault finding is the unit a Highwall Split system ??? Highwall Model starts with 42 outdoor or condensing unit start with 38 ! I need more infomation mate Fault codes are different on some models !
  • ullimani
    ullimani Nov 29, 2013
    Hi my carrier indoor unit model no 42-KGL-024Se+51MSG-024Se
  • ullimani
    carrier indoor unit model no 42-KGL-024Se+51MSG-024Se OPERATION indicator flash rapidly and this flash can't be fix even i stop the power breaker and wiat a while!! I'm in the ship working as a aircon technician. Let me how to solve the problem thank you. best answer is appriciated....
J Rosado
Level 3:
  • Master 1,202 Answers
  • Posted on Sep 23, 2020
J Rosado
Master
Level 3:
Answers
1202
Questions
Helped
498769
Points
3432
If the system has a condensation drain pump, there would be an interlock to keep the compressor or system off if the drain pump is full of water. A float switch, two wire circuit, jump them together and see if it runs then. The system may have a gravity drain and no pump, if so, this comment does not apply.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 13, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
30603
Points
My split A/C cards and control unit not working and it cost 350 US dollars to buy here in philippines. is it possible to replace the cards with ordinary temperature sensor and rotary switch like ordinary window aircon?
  • Cool AC
    Cool AC Sep 22, 2020
    You can use and install universal kit it's cheap way to
I have a Carrier model 42KPC019303. It turns off while running. The LED blinks five times, stops, and then blinks 5 times again in cycles. After a few minutes, it turns back on again and off again after a...
hello
1- you check thermostat .
2-maybe temp your house is below 26c.
3-you check fan condenser and evaporator .
4-maybe cut off low pressure system.
When I turn on the units inside, they run for s few minutes then shut off with one (left) light blinking.
Here is a tip about Mitsubishi Air Conditioners and how to get the manuals forall of the Mitsubishi line. The manual include both troubleshooting andinstallation.
Mitsubishi Air Conditioner Troubleshooting and Repair
heatman101
2helpful
All lights blinking - doesn't turn on
Try turning the power ot the unit off for a few minutes and then back on...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Turning On and OFF itself
low gas charge/pressure switch tripping
5helpful
2answers
1helpful
2answers
Continous blinking of the green light
Try shuting off breaker for a few minutes and try again. Wash out outside coil.
1helpful
Carrier A/C in RV won't run
check your breakers make sure when running unit this is the only thing on the breaker 15 to 20 amp be sure to keep a window cracked as well unit does freeze over so don't have all the way on cold
3helpful
Air conditioner turns on then shuts itself off immediately
There's something wrong with your aircon. Usually the lights will start to blink. Depending on the brand and model, the number of times it blinks will give you an error code which tells you what's spoilt. You may like to check this out http://www.astiquer.com/blinking.html
Top Carrier Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Jay Finke
Jay Finke
Grand Canyon Tech
Grand Canyon Tech
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
