SOURCE: removeing Jazzy 1170 wheel
Yes, you need a puller:
1 Remove the Nylock nut and washer (3/4 socket)
2 Pull the wheel with a 2 tooth wheel puller
SOURCE: 2 lights blinking on control stick. and chair
sounds like you need a new motor. 2 flashes indicates left motor.
SOURCE: jazzy 600 plugged into outlet.
Hello.Visit -www.alldatasheet.com its free.Download a troubleshooter as a PDF File of your product.Save + print if you choose to your Adobe Reader.Merry Xmas,any problem,please ask again Colin.
SOURCE: I just replaced the batteries
According to my 1170 manual the flashing lights are error codes. 1 red = low batt., 2 red = left motor disconnected, 3 red = Left motor wiring fault, 4 yellow = Right motor disconnected, 5 yellow = right motor wiring fault, 6 yellow = Inhibit active, 7 yellow =possible joystick fault, 8 green = possible controller fault, 9 green = Solenoid brake fault, 10 green = high batt. voltage
loose connections on power side of harness, computer reads this as low batteries sometimes
