I have a Ricoh Aficio and I cannot find how to use the stapling feature.
Are you sure it has stapling?
Some machine may show it on the control panel but it is an option that may or may not be installed.
Is there a stapler in the sorter?
If it does, then the stapling should come up as a finishing option when making copies.
On your control panel, there will be a Sort, Group and a Sort/Staple option.
Select this feature and it should staple your copies.
If you select this and it doesn't staple then it may be out of staples or the copy is not the correct size or orientation to allow stapling.
