Xerox DocuColor 12 Color Copier Logo
A
Anonymous Posted on Nov 09, 2017
Xerox docucolor 2045
My xerox 2045 will not feed any weight of material out of tray three. The front edge stops between the first and second set of drive rollers. I have thoroughly cleaned the rollers and they look in perfect condition. All springs look ok and in place. Be glad of a solution. This is a question for a xerox docucolor engineer....no less
Lawrence Oravetz
Level 3:
  • Xerox Master 10,558 Answers
  • Posted on Nov 09, 2017
Lawrence Oravetz
Xerox Master
Level 3:
Answers
10558
Questions
Helped
2699591
Points
29284
Try cleaning the paper dust off the pickup roller.
5 Related Answers
Anonymous
  • 2072 Answers
  • Posted on Feb 04, 2008
SOURCE: xerox phaser 7400
Remove the tray, first look for a piece of paper that has come out of the tray inside the tray area.
Make sure the rolllers are snapped into place. The easiest way to verify that is to remove another tray and compare them.
Look to see if all the switches and actuators are in place.
Make sure you hear the tray up motor running when you close the tray.
Also inspect the paper tray itself for broken items. Compare it to another tray.
Anonymous
  • 2072 Answers
  • Posted on Mar 11, 2008
SOURCE: Xerox 7750
In what direction is the mark? Is the defect a dent in the paper,that repeats or is it a crease in the direction of the paper feed? If it is a dent that is repeating, the cause would be the transfix roller. If it is in the direction of paper feed, there may not be much you can do, most of those ceases you can see when held sideways like that come from the rollers edges. Just the normal crease that can be created by the end of the roller.
You can open the covers on the machine and make sure there is no excessive buildup of ink on any of the rollers. It is possible there is to much pressure on one of them, but with certain types of paper, there may not be much you can do. I will research it more and get back with you on that issue.
One thing you can try, (because your marks can be comming from a defective fuser), set the machine to print 4 or 5 pages, then shut it off or unplug the printer in mid run. Carefully look at the jammed pages to and see where in the process the crease is comming from. Take note and let me know please.
The gray haze seems to also indicate a possible fuser issue, but moreso, it sounds like the black housing is over toned. Most likely cause of that is a bad housing or bad developer. The developer in that machine will become worn and need replacing. It will restore the contrast and should resolve background issues.
Anonymous
  • Posted on Nov 15, 2008
SOURCE: Xerox 6250 - Jam at Registration Roller
Ik heb een deregelijk probleem gehad, ook bij merdere printers tegelijk. De oorzaak was achteraf logisch. We hadden een nieuwe zending briefpapier waar een bepaalde film op zat waar de printer niet tegen kan. Logisch, want het kan niet zijn dat alle 3 printeres tegelijk hetzelfde mankeren.
Ander papier erin. De eerste hoeveelheid zal nog problemen geveb tot der olletjes vrij zijn van de vettigheid.
groeten,
G.Eijken te Hoorn
Anonymous
  • 2072 Answers
  • Posted on Feb 09, 2009
SOURCE: Frequent paper jams on Xerox PE220
You have to spin them backward to get them into a good position to clean them, They will resist you, but just take it slow and clean them with alcohol or formula 409 type cleaner.
But what will often cause jams on that machine is the seperation pad that is located on the paper tray itself. It will get very slick and allow 2 or more pieces of paper to feed, It is a small gray to black pad on the middle front of the tray, about 1/4 inch wide and and inch or so long, If it is smoothe scuff it with some scotch brite then order one or two.
Google a business called "the parts drop" and call Britt, they should have the pads and rollers at a fair price.
George Almeida
  • 9 Answers
  • Posted on Jun 02, 2009
SOURCE: How do i reset the second bias transfer roller on a Xerox 3535
I am afraid you will have to call in a qulified xerox technitian to reset the second bais transfer roll. It need to be done via a laptop connected to the m/c. The laptop needs to have a special program which only xerox techs. have in there possetion.
George
System Fault Code 004-329
I have also had this problem with our Xerox DocuColor 6060. It ended up being a corotron charger was wiggling loose and I just needed to re-seat it. Maybe this will help. For us it was the Yellow...
Xerox 2060 developer changing
error 010-314 and 010-315 for my xerox docucolor 2060-2045
Xerox 2060 horizontal line ymc problem
xerox 2060 horizantal lines problem how do i replace the part
Do you offer service repair on a Xerox 2045 in Woodbridge, VA area? We need Corotrons.
los antiguos corotrones eran hilos de oro....
pq no pruebas con un hilo fino de cobre....
I Have a subsystem fault 004-332 on a xerox 2045. Any ideas?
4.332 belt position failre as you can see the belt edge sensor sa detected that the drive belt is out of its position.
Xerox docucolor 1632 displays 006-382 and 004-347 fault codes
for the second message error :ibt edge sensor touches belt edge
for the first message error :ros sos c length
Offset catch tray failure docucolor 2045
there must be a fault with the tray or wiring. There is nothing else that can cause this fault
Docucolor-12 10-389 CODE
That is a fuser jam indication.
  1. Clear the Paper Jam and Obstructions in the Machine
  2. Make Sure the Paper is the Correct Size, Type, Weight, and Orientation
  3. Make Sure the Paper Supply Setting Matches the Type of Paper Loaded in the Paper Tray
  4. Load the Paper Trays Correctly
  5. Fan the Paper, Turn the Paper Over and Reload the Tray
If the above are all correct, you may just have a small piece of paper stuck on a sensor. Just has to be a small piece of paper directly on one of those. Also see if a sensor flag is dislodged. A sensor may be bad but not likely
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
