I picked my car up from auto painting and my abs, traction fault, and radio did not work..what happened and how do I fix this
SOURCE: 2001 S Type Jaguar ABS and Traction Control fault lights on
Hi First I suggest that you get a diagonostic check on ABS system. and then a visual inspection of the brakes. Warped brake rotors do not make noice, but the steering will start to judder when brakes applied at around speeds from 40 up . Possible cause that the vehile picked up something from road such as nylon/ plastic/stone Mike
SOURCE: Traction Warning Light & ABS light on.
one of your wheel sensors are bad. if you go to napa they will let you use a code reader for free and that will tell you which wheel it is and you can replace that sensor. they are kinda expensive @ around 100 bucks a piece.
SOURCE: XK8 ABS FAULT LIGHT COMES ON INTERMITANTLY PLUS
Number of possibilities. Most likely culprit is wheel bearings. Have these checked. Big heavy car and wheel bearings do take a hammering on XK and XJ's. Once they go, the wheel speed sensors are out of line with the tracking ring and a fault code is thrown. As the TCS uses the same sensor, this also throws a fault. Next in line is the ABS unit (it's hardly ever the main block, but ECU itself, companies on the net offer rebuilt units. Finally it can be the ABS pump unit - but the fault codes will show if this is the case - or you can pull the pump unit plug out of the ABS unit and see if it has continuity with a multimeter - should be a low number of ohms. 8 times out of 10, it is wheel bearing.
SOURCE: Hi, my car Jaguar S-type year 2000 shows abs
Could be your Rear ABS sensors , as that is the sensor that works for ABS and Traction control.
SOURCE: What does it mean when ABS Fault and disc light on
it means you need to have it daignosed, you have a malfunction in the ABS brake system, could be anyone of a number of things, abs module, wheel sensors, etc...
