Question about Canon FS10 Flash Media Camcorder
Can no longer see/record anything but black
HELP!
GR-D71, no longer records images
CCD (imaging chip) went bad and require replacement. Not a very expensive repair, but has to be done by professional.
Nov 04, 2009 | JVC GR-D71 MiniDV Digital Camcorder
Help record player like PYE black box TYPE S/Play CHANGEABLE HEAD
go to this website and check out the retro Crosley turntables? might jst be the ticket for you? failing that go to EBay and type in retro turntables? good luck.
mailto:info@needledoctor.com
Sep 16, 2009 | Audio Players & Recorders
Lens wont's pick up any picture - just shows black screen. Will record sound. Will play back old tapes on screen but will no longer record new footage
BAD CCD !
see the link for free repairs from JVC dont worry if u are out of warranty and not on list just call them PLS RATE ME FIXYA for help
http://www.jvc.co.uk/template.php?page=100102
Apr 15, 2009 | JVC Cybercam GR-D90 Mini DV Digital...
What are the best tapes to buy to recrod from your reel to reel. I have some tapes that record and some don;t. Is it becaue they old or defected. Help me out. vp
maxell or tdk (which is hard to find now)....if your reel is 7 inch you want 1800 ft, normal bias (lo noise hi output) tape (for 10 inch you will use the 2400 ft) ....anything longer your tape will be dragging (both while recording and playing) hope this is helpful...feel free to rate
Feb 22, 2009 | Quantegy 456 Reel-To-Reel Recording Tape
Creative zen mp3 player's screen suddenly went black with lines.
Most likely the video chip inside has gone bad. Best bet would be to contact Creative via their support number. I wish you the best of luck.
Dec 08, 2008 | Creative Labs Zen Digital Media Player
No picture
Check in the control remote of the dvd if they get the function progresive scan maybeyou push it by mistake and you activate it you need to deactivate.Good luck
Jun 22, 2008 | Protron PD-DVR100 DVD Recorder
Vidio recorder when i record it wont play back what is recorded but it will play pre recorded tapes Is it campatable for LG television please model no VR550/07
If it plays back pre recorded tapes then there is nothing wrong with that section of the unit. Does it playback audio and not picture or does it not playback anything.
Also, when trying to playback a recording what is seen of the screen? Snow(black and white dots or wiggly picture?
The unit uses two separate circuits to record and playback tapes. Is any thing else connected to the unit while you are recording? If you are using anything plugged into other ports on the recorder it may not see the camera input causing it to not record anything..
Feb 03, 2008 | Dishwashers
My video does not record for long enough
Hi the only problem you can solve yourself for this is by deleting some of the files you have saved on the phone if you have loads of new ringtones that you have put on or loads of photos saved on phone this will take up all the memory and wont allow you to record for long.
What i did on my phone is delete all the standard ringtones you get with the phone and all the ringtones you never use i also deleted anything that came with the phone like screen savers and wall papers delete all the ones you dont use and will never use after doing this that should give you longer recording time.
The best thing to do is go through the phone and delete any messages, pictures, ringtones, screen savers, wallpapers anything that you dont need or use as keeping pictures and ringtones on your phone uses lots of the memory up.
After you delete all this you should have got a longer recording time let me know how you get on ok
Nov 27, 2007 | Nokia 7373 Cellular Phone
Remote control problems
Answering my own question,Switch on recorder manually then hold down SETUP KEY and No 2 key at the same time.As this is a common fault with this recorder would advise taking note of this solution.
Oct 21, 2006 | Toshiba RD-XS34 DVD Player/HDD Recorder
Canon FS10 Flash Media Camcorder Logo
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
