Heating & Cooling Logo
a
adolphus Posted on Apr 11, 2014
LG inverter split air-condition the indoor blower is not working, is blinking
I on my LG inverter split air-condition it blow for 60 second and started blinking. what do check.
jw raabe
Level 1:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Contributor 15 Answers
  • Posted on Apr 11, 2014
jw raabe
Contributor
Level 1:
New Friend:
Night Owl:
Answers
15
Questions
0
Helped
2458
Points
23
Hi my lg inverter v is blinking lights when I switched on and not heating. when inspected out side, found the unit was buried in snow. so, I tried to switch on after clearing all snow and the fan too...
PDF]DEFINING COMMON ERROR CODES
www.lg-dfs.com/.../DFS-TP-AG-001-US_012H29_LGTechPaper_Error...
Aug 29, 2012 - Art Coolā„¢ Mirror High-Efficiency Single Zone Systems ... Refer to Service Manuals posted on www.lg-dfs.com to troubleshoot ... Location of light-emitting... No. of Times Indoor Unit LEDs Blink ... Inverter compressor DC voltage is too high.... unit inverter compressor PCB heat sink temperature is too high.
[PDF]"Universal" Split Systems - LG Comfort Cooling
Panasonic mini split air conditioner css9nkua error code h99 what does it mean
12.11 Freeze Prevention Control 2
ā€¢ Control start conditions
o During Cooling operation and soft dry operation ? During thermo OFF condition, indoor intake temperature is less than 50Ā°F or ? Compressor stops for freeze prevention control
o Either one of the conditions above occurs 5 times in 60 minutes. ā€¢ Control contents
o Operation stops
o Timer LED blinks and "H99" indicated
You may need the assistance of a technician. Service manual located here:
http://www.mcaair.com/docs/panasonicac/CS9NKUA%20CS12NKUA%20Service%20Manual.pdf
1helpful
Lg split system
my home outside ac unit isn't blowing out any air the coils are clean yet for some reason the freon leaks out from the base out to the pipe. what seems to be the problem amd how can I fix this 7_7_2013_2_24_50_pm.jpg
2helpful
3answers
2helpful
The heat sistem is not working well is working but 30% of eficency than it was working beafore.It hear like water on it ..help im frezzing
Air conditioning real definition is not giving cool but removing heat from the room. In same way for heating, it's not heating, removing cool from the room. When your indoor coil, air filter and blower wheel are full of dust, you won't get even 30% of cool or heat depend on your selection.
Simple solution for your problem is clean indoor unit completely. Check all sensor is working well. In heat mode keep temp minimum +3 degree than room temp. thanks and helpful.
2helpful
LG neo plasma air conditioner does not blow cold air
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure.
Thanks. Helpful?
2answers
My indoor blower is not working it blinks 8 times
This alarm state is a CH08 alarm. Which indicates that the indoor unit fan motor has a locked rotor. Solution is to check the indoor fan capacitor and replace or test the windings of the indoor fan motor. Note: the indoor fan motor is a BLDC fan motor and can not be replaced with any other motor. It runs of a voltage regulated frequency.
4helpful
4answers
Top LG Heating & Cooling Experts
Mike Cairns
Mike Cairns
MattS1978
Level 1 Expert
Jay Finke
Jay Finke
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
