Cars & Trucks Logo
melissa rutz Posted on Apr 11, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I reprogram my compustar remote to my 2003 Pontiac Montana EXT SE?
jean el ojeil
Level 2:
Sergeant:
  • Cars & Trucks Expert 195 Answers
  • Posted on Apr 11, 2014
jean el ojeil
Level 2:
Sergeant:
Answers
195
Questions
0
Helped
95453
Points
541
Hi Melissa
I have this procedure for Pontiac, try it
  • remotes you will be using on the vehicle. Once you program the remote. all previous remotes that were programmed will be erased from memory. The other remotes will not be functional until you program them again.
  • 1. Remove the key from the ignition.
  • 2. Remove the "BCM PRGRM" fuse from the fuse panel. Use the legend on the fuse panel to properly locate the "BCM PRGRM" fuse. Fuse panel is accessed by opening the front passenger door.
  • 3. Close all of the doors.
  • 4. Close the liftgate.
  • 5. Insert the key into the ignition, and turn to the ACC position.
  • 6. Turn the key to OFF and then back to ACC within 1 second.
  • 7. Open and close any vehicle door. A chime will be heard when the system enters into programming mode.
  • 8. Press and hold the remote LOCK and UNLOCK buttons simultaneously for 14 seconds.
  • IMPORTANT: After 7 seconds, a chime may be heard confirming successful synchronization. It is necessary to wait approximately 14 seconds for a second chime that will confirm successful programming.
  • 9. Repeat step 8 now for each additional remotes to be programmed including any existing remotes.
  • 10. Remove key from ignition.
  • 11. Install the "BCM PRGRM" fuse back into the fuse panel and test remote(s).
Good Luck
5 Related Answers
Anonymous
  • 55 Answers
  • Posted on Oct 16, 2008
SOURCE: replace thermostat 2003 pontiac montana
yes but with the right shaped wrenches and tiny hands it can be done without removing the exhaust crossover pipe
Anonymous
  • Posted on Jan 06, 2009
SOURCE: low beam headlights not working on 2004 Pontiac Montana extended
You headlight lamp have a diffuser mechanism which allows it to flip between the hight beam and low beam feature of the bulb. In fact, you high beam will function even if the low beam is not working.
I would recommend the purchase of the new headlight lamp. It would cost you you any where from $15.00 per unit to get a replacement lamp
Anonymous
  • Posted on Jan 12, 2009
SOURCE: how to put out the radio in montana 2003
there are 4 screws. two in the front behind the cup holder and two up underneath in the cupholder bay after the cupholder is removed. they are phillips head and 8mm I believe. this is all you need to remove the cover.
daves944
Dave C
  • 1050 Answers
  • Posted on Apr 08, 2009
SOURCE: 2003 Pontiac Montana Front Wheel Bearings
Remove the wheel, remove the hub nut, remove the brake caliper and rotor, put your socket and extension through the hub flange onto the bearing retainer bolts, undo them, release the abs sensor connector if it has it, remove the bearing and hub flange as an assembly, put the new one on and go backwards from here. Torque the hub nut to 180 ft/lbs, your done.
Anonymous
  • 15 Answers
  • Posted on Jun 20, 2009
SOURCE: 2003 pontiac montana leaks condensate water in the drivers floor
Bet the drain is clogged with leaves. Look under the blower motor under the hood. Can almost be that the cowling has been filled with leaves at one time or another. Got to clean that stuff out every now and then.
Can you put a transmission from a 2002 chevy impala in a 1999 Saturn sw2
about replacing a transmission with one from a Junkyard or cross referencing them. and to show you that not all 4T65E transmissions are interchangeable, although they look alike. Guys with the comp g package or the Impala police option often find this out the hard way.
Your car and the potential donor car will have a tag in the trunk (usually under the spare tire cover) that lists the RPO codes for your car, along with your VIN. RPO=Regular Production Order. Several of these codes relate to the transmission, and you will need them to begin to find a proper match. If you can't find the RPO tags, you can look up the RPOs for a nominal fee ($5) according to the VIN number at the following website: www . compnine . com .
I know these transmissions are different in at least 5 areas, and you have to match each area for a proper swap.
FIRST is the transmission type, which relates to torque converter size, the strength of the internal gears, and the strength of the differential. Here are the basic types along with their RPO codes:
M15 - 245 mm (9.6 in) torque converter
MN3 - 258 mm (10.2 in) torque converter
MN7 - 258 mm (10.2 in) torque converter and heavy-duty gearbox and differential (see 4T65E-HD)
MD7 - 245 mm (9.6 in) torque converter (Chinese version)
M76 - 245 mm (9.6 in) torque converter (with all-wheel drive capability)
You will want a match these RPO codes.
SECOND is the final drive ratio. The PCM can detect the difference, and in some cars may not engage if the correct final drive is not present. Here are the RPO codes for the four different final drives used in the transmission.
FQ3 - RATIO TRANSAXLE FINAL DRIVE 2.86;
FR2 - RATIO TRANSAXLE FINAL DRIVE 2.93;
F83 - RATIO TRANSAXLE FINAL DRIVE 3.05;
FR9 - RATIO TRANSAXLE FINAL DRIVE 3.29;
To narrow year search for potential cars, the following site have pretty good info on the final drives used on various cars. Click on the years of the cars in question.http://www.gmtuners.com/transmission/index.htm
THIRD is the converter stall speed. There will be small differences for most cars as it is based on car weight as well as final drive value and engine ratings. Reusing the cars original torque converter will address that area. Some indication of stall speed value is given in the K-factor information in the above gmtuners page. This bottom of this page from the gmtuners website will show you how to decipher the four digit code on the torque converter. http://www.gmtuners.com/gmtransinfo.htm
FOURTH, the torque converter needs to have the correct lockup clutch friction material for the PCM that controls it (regardless of HD nor not). This changed over the years. The newer ones can be used on older transmissions with calibration changes, but older type in newer transmissions will fail. Reusing the cars original torque converter will address that area.
FIFTH is area is electrical compatibility, and this is what trips up a lot of guys. 3 different electrical interfaces to the transmissions were used from 97-08. Some of these differences had to do with how the PCM determined what gear the transmission was in, or was commanded to be in. If you look on a GM parts web site, you will see that three different internal harnesses are available for the 4T65E. Each of the three harnesses is listed below along with the cars that use the harness. Your car and the donor car will have to match. If you have any additional insight, please leave me a comment and I can correct this post.
CARS USING HARNESS 24241204
Buick Century 4DR Custom2000, 2001, 2002
Buick Century 4DR LIMITED2000, 2001, 2002
Buick Lesabre 4DR CUSTOM1998, 1999
Buick Lesabre 4DR LIMITED1998, 1999
Buick Park Avenue 4DR Base1997, 1998
Buick Park Avenue 4DR ULTRA1997, 1998
Buick Regal 4DR GS1998, 1999, 2000, 2001, 2002
Buick Regal 4DR LS1998, 1999, 2000, 2001, 2002
Buick RENDEVOUS 4DR2002
Buick Riviera 2DR Base1997, 1998, 1999
Chevrolet Lumina 4DR Base w/ 3.1L (LG8) eng2000, 2001
Chevrolet Lumina 4DR LTZ1997, 1998, 1999
Chevrolet Monte Carlo Z341997, 1998, 1999
Chevrolet Venture2001, 2002
Oldsmobile 88 4DR Base1997, 1998, 1999
Oldsmobile 88 4DR Regency1997, 1998
Oldsmobile 88 4DR Royale, Base and LS1997, 1998, 1999
Oldsmobile 88 4DR ROYALE LSS1997, 1998, 1999
Oldsmobile Intrigue 4DR Base1998
Oldsmobile Intrigue 4DR GL1998, 1999, 2000, 2001, 2002
Oldsmobile Intrigue 4DR GLS1998, 1999, 2000, 2001, 2002
Oldsmobile Intrigue 4DR GX1999, 2000, 2001, 2002
Oldsmobile Silhouette1999, 2000, 2001, 2002
Pontiac Aztek Hatchback Base and GT2001, 2002
Pontiac Bonneville 4DR SE1998, 1999
Pontiac Bonneville 4DR SSE1997, 1998, 1999
Pontiac Grand Prix 2DR GT1998, 1999, 2000, 2001, 2002
Pontiac Grand Prix 2DR GTP1999, 2000, 2001, 2002
Pontiac Grand Prix 4DR GT1998, 1999, 2000, 2001, 2002
Pontiac Grand Prix 4DR GTP1999, 2000, 2001, 2002
Pontiac Grand Prix 4DR SE2000, 2001, 2002
Pontiac MONTANA Base1999, 2000, 2001
Pontiac MONTANA EXT MOBILITY SPECIAL2002, 2003
Pontiac MONTANA MPV1999, 2000, 2001
Pontiac MONTANA MPV BASE2002, 2003
Pontiac MONTANA MPV EXT1999, 2000, 2001, 2002
Pontiac MONTANA MPV EXT BASE2002, 2003
Pontiac MONTANA MPV EXT UPLEVEL2002, 2003
Pontiac MONTANA MPV SPECIAL2000, 2001, 2002, 2003
CARS USING HARNESS 24241205
Buick Lesabre 4DR CUSTOM2000, 2001, 2002
Buick Lesabre 4DR LIMITED2000, 2001, 2002
Buick Park Avenue 4DR Base1999, 2000, 2001, 2002
Buick Park Avenue 4DR ULTRA1999, 2000, 2001, 2002
Chevrolet Impala 4DR Base2000, 2001, 2002
Chevrolet Impala 4DR LS2000, 2001, 2002
Chevrolet Monte Carlo LS2000, 2001, 2002
Chevrolet Monte Carlo SS2000, 2001, 2002
Oldsmobile Aurora 4DR 3.5L2001, 2002
Oldsmobile Aurora 4DR Base2001, 2002
Pontiac Bonneville 4DR SE2000, 2001, 2002
Pontiac Bonneville 4DR SLE SSEI2000, 2001, 2002
Pontiac Bonneville 4DR SSEI2000, 2001, 2002
CARS USING HARNESS 24237264
Buick Century 4DR Custom2003, 2004, 2005
Buick Century 4DR LIMITED2003
Buick LaCrosse 4DR Base2005, 2006, 2007, 2008, 2009
Buick LaCrosse 4DR CX2005, 2006, 2007, 2008, 2009
Buick LaCrosse 4DR CXL2005, 2006, 2007, 2008, 2009
Buick LaCrosse 4DR CXS2005, 2006, 2007, 2008, 2009
Buick LaCrosse 4DR SS2008, 2009
Buick Lesabre 4DR CUSTOM2003, 2004, 2005
Buick Lesabre 4DR LIMITED2003, 2004, 2005
Buick Lucerne 4DR CX2006, 2007, 2008, 2009, 2010, 2011
Buick Lucerne 4DR CX CLOTH2009, 2010, 2011
Buick Lucerne 4DR CX CLOTH PLUS2009, 2010, 2011
Buick Lucerne 4DR CXL2006, 2007, 2008, 2009, 2010, 2011
Buick Lucerne 4DR CXL LEATHER2009, 2010, 2011
Buick Lucerne 4DR CXL LUX & CONFIDENCE2009, 2010, 2011
Buick Lucerne 4DR CXL LUXURY2009, 2010, 2011
Buick Lucerne 4DR CXL SPECIAL EDITION2006, 2007, 2008, 2009, 2010, 2011
Buick Lucerne 4DR CXL ULTRA2009, 2010, 2011
Buick Park Avenue 4DR Base2003, 2004, 2005
Buick Park Avenue 4DR ULTRA2003, 2004, 2005
Buick Regal 4DR GS2003, 2004
Buick Regal 4DR LS2003, 2004
Buick RENDEVOUS 4DR2003, 2004, 2005, 2006, 2007
Buick Rendezvous2003, 2004, 2005, 2006, 2007
Buick TERRAZA2005, 2006, 2007
Chevrolet Impala 4DR 50TH ANN SPL2008
Chevrolet Impala 4DR Base2003, 2004, 2005
Chevrolet Impala 4DR FLEET 1FL2011
Chevrolet Impala 4DR FLEET 2FL2011
Chevrolet Impala 4DR LS2003, 2004, 2005, 2006, 2007, 2008, 2009, 2010, 2011
Chevrolet Impala 4DR LT2006, 2007, 2008, 2009, 2010
Chevrolet Impala 4DR LT 3.52006, 2007, 2008, 2009, 2010, 2011
Chevrolet Impala 4DR LTZ2006, 2007, 2008, 2009, 2010, 2011
Chevrolet Impala 4DR POLICE2004, 2006, 2007, 2008, 2009, 2010, 2011
Chevrolet Impala 4DR SS2004, 2005, 2006, 2007, 2008, 2009
Chevrolet Impala 4DR TAXI2011
Chevrolet Malibu 4DR SS2006, 2007
Chevrolet Malibu Hatchback MAXX SS2006, 2007
Chevrolet Monte Carlo Base2003, 2004, 2005
Chevrolet Monte Carlo LS2003, 2004, 2005, 2006, 2007
Chevrolet Monte Carlo LS LS2003, 2004, 2005
Chevrolet Monte Carlo LT2005, 2006, 2007
Chevrolet Monte Carlo LT 3.52006
Chevrolet Monte Carlo LTZ2006
Chevrolet Monte Carlo SS2003, 2004, 2006, 2007
Chevrolet Monte Carlo SS HI Sport2004, 2005
Chevrolet UPLANDER2005, 2006, 2007, 2008, 2009
Chevrolet Venture2003, 2004, 2005
Oldsmobile Silhouette2003, 2004
Pontiac Aztek Hatchback Base2003, 2004, 2005
Pontiac Aztek Hatchback GT2003, 2004, 2005
Pontiac Bonneville 4DR SE2003, 2004, 2005
Pontiac Bonneville 4DR SLE2005
Pontiac Bonneville 4DR SLE GXP2004, 2005
Pontiac Bonneville 4DR SLE SSEI2003
Pontiac Bonneville 4DR SSEI2003
Pontiac G6 Base2006, 2009
Pontiac G6 GT2007, 2008, 2009f
Pontiac G6 GT UPLEVEL2009
Pontiac G6 GXP2006
Pontiac Grand Prix 4DR Base2006, 2007, 2008
Pontiac Grand Prix 4DR GT2003, 2004, 2005, 2006, 2007
Pontiac Grand Prix 4DR GT22004, 2005
Pontiac Grand Prix 4DR GTP2003, 2004, 2005, 2006
Pontiac Grand Prix 4DR GXP2005, 2006, 2007, 2008
Pontiac Grand Prix 4DR SE2003
Pontiac Grand Prix 4DR SE12003
Pontiac MONTANA EXT MOBILITY SPECIAL2003, 2004, 2005
Pontiac MONTANA MPV BASE2003, 2004, 2005
Pontiac MONTANA MPV EXT2003, 2004, 2005
Pontiac MONTANA MPV EXT BASE2003, 2004, 2005
Pontiac MONTANA MPV EXT UPLEVEL2003, 2004, 2005
Pontiac MONTANA MPV SPECIAL2003, 2004, 2005
Pontiac SV-62005, 2006, 2007, 2008, 2009
Saturn Relay2005, 2006, 2007
GM FWD Transmission ID chart
I have a 2013 Honda Accord with push start and ever time i unlock the car and open the door after it is remote started it shuts off. Is there a fix for this?
Yes, you must have the remote start reprogrammed, probably can only be done at dealership if factory or by the installer if aftermarket.
I have a compustar from-2w9000-ss remote and a button was pressed,locked me out ,what buttons do I press to get it to work again
PRIME 9000 1-Mile Range, 2-Way Select - Compustar
www.compustar.com/product/prime-9000/
Compustar1-Mile Range, 2-Way Model: RF-2W9000-SS ... The classic Compustar look that made us the top remote start brand in North America. ... The screen keeps you updated on whether your doors are locked and in the event of an alarm trigger, the ...
Compustar RF-2W9000-SS remote kit failure? - 8th Generation Honda ...
www.8thcivic.com > ... > ICE, Electrical, Security, & Navigation
Jan 8, 2015 - 4 posts
I have had my Compustar RF-2W9000-SS remote kit and secondary remote ... on my 2008 Honda Civic SI Coupe, FG2, at a compustar authorized dealer. ... my remote was not responding to my car (the unlock/lock, autostart, ...
CompuSTAR Starters - TheCarSalon.com
www.thecarsalon.com/home/automotive/remote-starters/compustar/
Either tap buttons I and III or Lock and Trunk simultaneously on your remote. ... The introduction of the RF-2W9000-SS in 2010 ushered in a new generation of .
RF-2W9000-SS by Compustar from Remotely Started MN
remotelystartedmn.com/product-details.php?product-id=40
How do I repair the antitheft system after jump starting my 2003 Pontiac Montana?
try using a fault scanner to reset the CPU program in the ECM
Como cambiar las bujias de montana pontiak
Tengo una Pontiac montana 2001 y quiero cambiar las bujias traseras me podrian decir como le podria haser para quitarlas estan muy escondidas
1helpful
When I try to start my 2003 montana, the relay under the hood clicks but the starter will not turn. I have checked the starter assy and it is OK. I think it may be my security system acting up. Can the...
Most likely the passlock sensor will need replaced and the key reprogrammed unless you recently replaced a key that never got programmed listed below is detail instructions on reprogramming a the passlock to the key.
PASSKEY LOCKOUT RESET ALL GM CARS 1999 AND UP
1) Put the key in the ignition and turn to the "ON" position. Leave it that way for 10 minutes. After 10 minutes turn the key and take it out. Repeat this process (2) more times (3 times, 30 minutes total) This should reset the PASSKEY system to recognize your key
5helpful
2answers
Replace thermostat 2003 pontiac montana
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
