Under properties it says 100% used, but there's nothing there. The blue light is on, I've checked all my connections, restarted it, etc...
SOURCE: Access denied on an external harddrive.
quick fix is to format the hard drive.. otherwise you'll have to get your data back with a seperate program...
SOURCE: PC does not detect Seagate 500GB external hard drive
Try using the device on another PC & see if it works. if it does then you have a issue with your PC. whast the OS you are using? also try another USB port.
SOURCE: i/o error in external hard
make sure all the connections USB, sata and electrical are secure and working properly
SOURCE: folder structure showing 0 files on external HD -after powersurge
You may use data recovery software to see if you can rescue the files on your external HD.
It may unable to recover all the files, but at least most of them.
