Samsung SP43J6HD 43" Television Logo
Picture like negativ - Samsung SP43J6HD 43" Television
Parpadea la luz verde de encendido .la luz roja de lamp tambien
SOY NICO,Jose si es la D que parpadea es el sensor ,3 gear pressure switch tienes que cambiarlo, me pasaba lo mismo lo cambie y problema resuelto,cuesta 67 dollars con los taxes en el dealer,lo puedes cambiar tu mismo,busca este codigo en internet P0845 y mira las fotos donde esta ubicado,esta es la imagen ,quita la rueda del lado del chofer y lo veras,para cambiarlo desconecta el negativ bateria,,4_28_2012_1_09_18_am.gif
Lcd negativ
A brand and model number and a clearer description of what unit is not doing?
I need to know what wires are for what on my Pioneer Head unit model number deh-p2900mp.
black=negativered=live yellow is for memory witch should be conected to a permenent live blue is for electric areal and the rest are for speakers
Failed to start,no power
If your battery is fully charged check the negativ cable to the frame. Often corrosion or a loose cable will prevent a proper start. Depending on the model you also want to check the electrical's system for the fuse. Other problems could be loose or broken wires from starter to switch, ignition module etc.
Follow your wires!...
1helpful
I want to use PL filter with DMW-LW 55. Can I
No, there's always going to be a compromise.
In this case you'll find that having the wide-angle converter further from the lens will affect the angle of view a little, but the main effect will be vignetting. All you can do is try it and experiment with different aperture settings to minimise the effect. In any case, you'd be better off in every respect by mounting the DMW-LW55 directly to the adapter, and then mounting the adapter onto the filter. To do otherwise will lead to dreadful colour fringing as the adapter and wide angle converter lenses are optically matched and designed to be a particular distance apart.
Need to know what is positive and negativer on dell vostro 1400 battery the charging system is not working and need to try to charge the battery to get information off of hard drive. the system will work...
remove hard drive and insert into a portable encoseure this will allow you to remove all data from drive saving time and giving you a protable storage drive to boot
total cost 30.00 and you can use the drive for backups
6helpful
2answers
I have exactly the same thing
M is maintainance light to turn it off turn off the ignition push set button and turn on the ignition.Wait 3 seconds until the display reapeats positive R mark and negativeR mark 3 times and goes off and there ya go
2answers
Nology hot wires and Nology silver spark plugs
It is not possible to use Nologi non resistor silver spark plugs together with Nologi Hot wires on my Tiburon 2003. I guess it goes for all Tiburon from 2002 to 2006 with the 1,6 liter DOHC Alpha Engine. But I am still working on it and if I get anything to solve this problem I will be back to tell.
Sound
Dear Sir:
Here we can help to solve your problem.
Please follow this guidelines in order to start the sound on your pc.
1. check if the plug of the speakers are connected at the back pannel of your pc, mainly at the center of the back connetors, marked with the speaker simbol.
2. If your speacker are feed with DC, kindly check if your cord is already plug to the wall connector.
3. check of the PC speakers has an switch power on.
* if there is no sound at this stage, please make the following tips.
1. at the right down corner of your pc monitor, check if ther is an icon speaker with some negativ simbol, if there exists please doble click on then.
2. At this point the speakers can make a some kind of sound.
Kindly post if your pc can not make some sound.
Also rate my solution, thank you.
Bridged lanzar amp
no idea, but i think you should leave the subs the right way in the box
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
