How do I tun on hold music off. Is there a particular phone on the system to access for task?
SOURCE: We lost power and when our Meridian M8X24 phone
Sounds like your norstar system needs to be reprogrammed because norstar defaults back to only 2 lines when the inturnal battery fails.If the inturnal battery has failed and you reprogram this phone system and you have another power fail you will have to have you system reprogrammed again.Time for new system.
SOURCE: I have a Norstar T7316E phone system. I need to
Depending on the type of voicemail you have It can be accomplished by calling in to the office and when the main greeting starts playing press **, the administrator mailbox number, the password and the pound key (the administrator password must be changed from 0000). Once in the mailbox press either 9 or 99 at this point you can re record the main greeting.
MANY TIME A PERSON DIALS WITHOUT REALIZING THAT THE ACCEPTANCE CODE NEEDS TO BE INSERTED FIRST THE Nortel T7316E?...If you want to
temporarily turn them off use do not disturb (feature 85, feature #85 to
turn Do Not Distrub off) Turning off the ringing permanently will require you to program the set. Programming is done on M7310,
...regards John
If just for your phone Feature #86. If for the system you have to go into system programming and turn it off.
