After machine on, water filled, the drum does not turn
You need to know if your machine is band driven(older model) or gear driven(newer model). Google model to find out or look it up in manual if you have it.
If older model the rubber belt is broken and needs to be replaced OR if newer model the gear that turns the drum is burned out and needs to be replaced. Either way, it best to have a service tech come out and fix it. The rubber band might be old and hard to find & if gear & motor are gone may be too expensive to fix, cheaper to buy another unit.
