A
Anonymous Posted on Apr 11, 2014
We have a c252 and the black toner don't print solid black
Black toner don't print solid black as it were before
Norman Weimar
Level 3:
  • Konica Minolta Master 7,035 Answers
  • Posted on Jan 10, 2016
Norman Weimar
Level 3:
Answers
7035
Questions
Helped
1913720
Points
11960
How does it print? have you replace the black image unit? NOT TONER THE IMAGE UNIT BELOW THE BLACK TONER CART
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5 Related Answers
Anonymous
  • 118 Answers
  • Posted on Feb 08, 2008
SOURCE: Page not printing properly
It would definitely be a High Voltage problem. The printer uses HV to create the image on the drum and transfer it to the paper. The laser erases the charge on the drum and wherever there is no charge the toner sticks and forms the image. The charged area repels the toner. Theory is the HV charge produced by the Controller board is diminishing and as it diminishes, the pages get blacker. If you let it recover the HV gets back to normal. You would need to replace the controller board. It occupies most of the bottom part of the printer. You can see it if you lift the small panel in the back of the printer.
Anonymous
  • 2120 Answers
  • Posted on Jan 17, 2009
SOURCE: printing all pages as black
Open up the left side door and push in all of the chargers to make sure they are seated.
Anonymous
  • 1142 Answers
  • Posted on Mar 24, 2009
SOURCE: HP 2550L printer
Theblack print cartridge is empty or missing. The black-print-cartridgelight is blinking, and then printer stops printing. An error 40208 iswritten to the event log. The printer cannot detect the print cartridgecorrectly. Action
  1. Reinsert or replace the print cartridge.
  2. If the print-cartridge light is still blinking but the Attention light is not on, turn the printer off, and then back on.
  3. If the problem continues, contact HP Customer Care at http://www.hp.com/support/clj2550 or see the flyer that came in the printer box for other contact information.
Anonymous
  • 22 Answers
  • Posted on Nov 23, 2009
SOURCE: Kyocera KM 2030 Changed the toner and it is now
You need to clean the corona unit again.
unkl foddy
  • 120 Answers
  • Posted on Feb 24, 2011
SOURCE: toner blotched on printed material When printing
If the line has a 1/8" white margin on either side, clean your glass and mirrors.
If the line is all the way across your page, consult your users manual for cleaning the sawtooth electrode (open the front door and take out your waste tank, there is a green rod on each drum cartridge you can pull and hear a zipping noise) and cleaning the laser lens (there should be a cleaning wand under your waste tank, turn pad side down and insert in the gap underneath your drum cartridge)
My XANTE illumina is printing solid cyan or magenta, no print. WHY?
Chevy Illumina? All questions need full 'make model (what it is)'. Or we guess. My guess is that you ran out of black toner.
https://www.google.com/search?q=illumina+is+printing+solid+cyan+or+magenta+no+black
I emptied the toner waste container on my Samsung CLX-6260 FD printer. Now all prints are completely black. Any suggestions on how to fix?
emptying the waste box is not recommended but should not cause solid black prints. solid black prints indicate a problem with the image formation, primary or secondary transfer, or laser units. reset all toners and make sure the toner rack is slid in fully.
Black lines running down on the Konica Minolta bizhub c252 copier?
Does this happen when you print? does this happen when you make copies on the big glass. Does this happen when using the document feeder?
Solid red light on this symbol <...> also
first change the black toner cardrige and try to run the printer most of the time the problem is gon after the change.
Printing black
is the copy/print full black or have streaks or have dots, or ...
First, remove the toner crg., and check the drum surface if it has toner leftovers or spots or streaks, or... if so replace the toner crg.
btw. It also can be the fixing unit, but if these is the problem then the toner will not be "baked" on paper and it can be wide solid black stripe on corner.
Hope that helps!
I have a Samsung ML-2525 BW laser printer. Recently, the red bar second from the top started flashing and then it went solid. I thought this was because of the ink toner, and the cartridge was running low...
I guess it FixYa didn't accept my (very long, but totally correct) solution that I took the time to type. Because I refused to "sign in".
Here's the short version. Load Paper. The same thing happened to me. I replaced the toner cartridge with a new one (because of a FLASHING red light for several weeks) after the red light went to STEADY red. But it still would not print. The paper was "out". When I'd refilled the paper-tray, it printed fine. I had just ASSUMED that the steady-red light meant toner was finally OUT. WRONG! That steady-red light had nothing-to-do with toner; it meant "you're out-of-paper". Don't get confused like I did. Refill the paper-tray. Then take that expensive NEW toner cartridge OUT, and put the OLD toner cartridge back in. And keep using the "dregs" of the toner out of the old cartridge for several more weeks. And DON'T get confused by the paper-is-out condition making that red light STEADY.
2answers
The yellow spot is blinking and the black dot is
the solid light means toner is low. Blinking usually means either the cartridge is out of toner or the cartridge is having a technical problem. If you pull the yellow toner cartridge and put it back in with no change in result, you will need to replace the yellow toner cartidge
Dell 1720 lazer printer only printing solid black pages
The corona wire is not charging the drum properly. Try pulling the toner cartridge out and then re-seating it. If this doesn't work, try a new toner cartridge as the corona wire is usually included in the cartridge.
If you are using a refill toner, there's an outside chance that the supplier put toner with the wrong electric charge in the cartridge. Again, changing the cartridge should fix this(assuming the replacement is from another batch).
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
