Question about Konica Minolta Bizhub Press C6000 Copier
Konica minolta continuous printing
Continus warmup problem
  • Konica Minolta Master
  • 6,850 Answers
Have you had the developers and drums replaced or does the screen say Replace PC Drums? There are certain house chores the copier does before "Ready to Copy" it is waiting for them to get done, so that equals "Please Wait". One big item is making sure the developer and toner are properly mixed inside the developing units next to the drums. Did you recently replace the drums and the developer if so did you clear the counters for the drums and developer, FIRST? IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developers and a new drums and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the drums unit replace the developer. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. .
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jan 10, 2016
SOURCE:
  • 62 Answers
SOURCE: Printing from an IBM AS/400 to a Konica Minolta 350 printer
An HP5si PCL5e driver may work for just basic printing.You will not have any extras like finishing or dulpexing.
Posted on Oct 21, 2007
  • 214 Answers
SOURCE: Konica Minolta bizhub C250
i think that your fax is not set up right, or maybe the machine is missing admin and machine e-mail address, that can cause too this problem.
Posted on Dec 31, 2007
  • 16 Answers
SOURCE: Konica Minolta magicolor 2430DL
Open the top cover. Remove the drum (part with long green handle). Below the drum you will see a strip of glass about 4-5 inches long. Take a cloth and wipe across the glass.
This will normally clear up any white lines in your print.
Posted on Jul 19, 2008
  • 167 Answers
SOURCE: Print Booklets with Konica Minolta Biz Hub C650 Printer
Select Print, and then "Properties"
Layout Tab - select Print Type: Booklet
Basic Tab - Select original size and then size of PAPER to be printed. 11x17 is standard 8.5x11 book when folded.
Finish Tab - select saddle stitch.
Thats it, easy as pie.
Posted on Feb 17, 2009
SOURCE: Konica Minolta Magicolor 4690MF gives 0502 error.
machine trouble 0092 service call
This happen after I cleaned the waste box for Konica Minolta Magicolor 1600W
Posted on Mar 08, 2010
My konica minolta magicolor 7450 is low on C cartridge, is there a way to disable that one cartridge and continue printing with the rest. i just need b/w text printed.
No, you can't disable the cyan or other color. The printer is build to work with all 4 cartridges. If one of them is empty you can't print. The solution in this case is to reset or change the cyan chip.
Jun 15, 2018 | Konica Minolta Office Equipment & Supplies
What can I do to remove Code Error C-D252 on Konica Minolta C451 bizhub
Do you have a print controller IC 409 with this machine need to know prior to continuing to trouble shoot.
Feb 17, 2018 | Konica Minolta Office Equipment & Supplies
My Konica bizhub c451 is showing p6p7p9p8 and it keeps sterbilizing without showing ready to copy pleas what do I do
Check the Transfer Belt assy,
Remove and Clean properly
Remove all Imaging Unit and shake properly and put it again.
P6/7/8/9 indicating all Imaging units are not in good condition.
So at warmup, color patch not getting properly generated
Dec 22, 2016 | Konica Minolta Bizhub C451 Copy-print-scan
My bizhub c451 is still printing only cyan and black after we change toner catridge, what could be the problem please
The problem could be the laser that scans the image or the detectors that see the colors. It could also be a problem with the power supply or the main board. This is not going to be cheap. If you want to continue, you should download the service manual.
http://www.printcopy.info/?mod=docs&brand=Konica-Minolta&gID=15037
Jul 20, 2015 | Konica Minolta Bizhub C451...
Konica Minolta Unit A-1 empty
Yes they are the Image unit, replace the one required, they are not toner.
May 19, 2014 | Konica Minolta Office Equipment & Supplies
I have changed the setting of the dev unit of the Konica minolta C360 to No life But it still says replace unit. The printer is still giving excellent prints
it continue to showing this error and u have to press ok
just make prints till print are coming ok
after that u have to change unit
Aug 06, 2013 | Konica Minolta Bizhub C360
I have a Bizhub 250/350 Konica Minolta it has a
the device takes too long to warmup. try switching off then back on when you see the message. if that does not work you will have to call for a technician i'm afraid. good luck
Apr 09, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
My Konica Minolta MC2300DL will not print. It is
You can change the 2300's menu setting to ignore empty toner cartridges and keep printing. There are 2 steps:
Step 1:
Press Menu/Select, then "right arrow" until you see ENGINE. Press Menu/Select again and then "right arrow" until you see TONER EMPTY. Press Menu/Select and you'll see STOP. Press "right arrow" once to change to CONTINUE. Press Menu/Select.
Step 2:
Press "right arrow" until you see AUTO CONTINUE. If set to ON, press the "Cancel" button and you're ready to print. If set to OFF, press Menu/Select, then right arrow to change to ON, then Menu/Select to enter. It will say "ON IS SELECTED." Then press the "Cancel" button and you're ready to print.
Mar 13, 2010 | Konica Minolta magicolor 2300DL Laser...
Konica/Minolta majicolor 2300DL printer
pleas check the driver settings, maybe there is a setting fit to paper or something.
May 07, 2008 | Konica Minolta magicolor 2300DL Laser...
Minolta 2300DL feed problem
This is a common problem with the majic colors. There is a solenoid inside the machine that needs to be replaced. Not an easy job. This should be done by a tech.
Aug 14, 2007 | Konica Minolta magicolor 2300DL Laser...
Konica Minolta Bizhub Press C6000 Copier Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
