When I put a sim card,it says phone restricted,put the codes,It's restricted to Swisscom Switzerland,I need restricted codes ,so my phone to work with other operators.Help me...
Hai, If you want restriction code you can get it from your network provider or online providers. After getting the unlock code you can check at Mobileunlockguide.com for free step by step unlocking instructions and unlock your Nokia 2690 mobile easily.
SOURCE: NOKIA PHONE RESTRICTION CODE
I HAVE A T MOBILE 6133 AND THE IME NUMB R IS 358968011049869 AND I NEED TO PUT MY ATT SIM CARD INTO IT. AND I NEED A RESTRICTIO CODE. PLEASE HELP ASAP
SOURCE: nokia 5310 restriction code
Hello there, your IMEI no. is 359813010646423 and the code master code is this, 5146730640.
When you enter the master code, the current security code of your phone will be override, so i suggest that return the master code to default which means 1234, and then you cab change that lately.
Hope I help... :D
SOURCE: O2 restriction code required for nokia 6303c
Try restriction codes here http://www.wickedunlock.com/nokia-6303-classic/rs11wp9/
SOURCE: Need restriction code for my nokia 2330c. When I
Nokia Restriction Codes are used to remove restrictions added to a Nokia phone by your original carrier so it will only work with their network. It is also known as an unlock code or an unlock password.
Well if you are tied to a particular network all you have to do is to unlock your phone to use it any other GSM network. You can get the unlock code through online. Give your IMEI number & get the unlock code for ur mobile .............You also get through online..........I will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website.
