Check the wiring behind the in-dash the wires are white n greay make sure that the lines on the wire r hooked up from harness to harness n the solid wire r 2 but it could be that ur door speakers are blown 2...
To get all 5 speakers, you will probably have to get a new sound card, one that is 5.1 compatible. Most computers with on-board sound will ship with only support stereo sound. If you look at where you plug in your speakers, if there are only 3 slots, you have only stereo sound. If there are more, you may have to plug into different spots on the sound card.
my brother has a 1993 Honda accord and had the same issue, we put it different speakers and it worked fine, don't know what the problem was but it worked
2001 Dodge Ram 1500 Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Red
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Black/Dark Green
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange/White
Car Stereo Antenna Trigger Wire: Yellow
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Some sound fields have reverberant effects that need adjusting so the levels become audible, such as in "stadium" mode. While playing one of these sound fields, navigate through the speaker setup menu and make adjustments to the "effects" percentage, and levels. Be aware however, that only in 4 channel stereo mode will your surround speakers produce sound 100% of the time. Also, in any form of Dolby Pro Logic mode you will hear more sound from the surround speakers originating from stereo source material than from monoaural material...example, a television station broadcast in stereo versus mono.
here is the factory harness wires and what they do, recheck thayt it all matches up.
1995 Nissan Pickup Truck Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink Car Radio Accessory Switched 12v+ Wire: Blue Car Radio Ground Wire: Gray Car Radio Illumination Wire: Red/Blue Car Stereo Dimmer Wire: Red/Yellow Car Stereo Antenna Trigger Wire: N/A Car Stereo Amp Trigger Wire: N/A Car Stereo Amplifier Location: N/A Car Audio Front Speakers Size: N/A Car Audio Front Speakers Location: N/A Left Front Speaker Positive Wire (+): Pink Left Front Speaker Negative Wire (-): Blue Right Front Speaker Positive Wire (+): White Right Front Speaker Negative Wire (-): Black Car Audio Rear Speakers Size: N/A Car Audio Rear Speakers Location: N/A Left Rear Speaker Positive Wire (+): Light Green Left Rear Speaker Negative Wire (-): Violet Right Rear Speaker Positive Wire (+): Blue Right Rear Speaker Negative Wire (-): Pink -->
Your systemn is designed and built to perform 2.1 sound. If you want 5.1 sound you can do 2 things, connect another pair of speakers to the same speakerterminal as your front speakers, however this produces 5.1 stereo sound and not 5.1 surround sound. You can buy a new system that has the proper connections.
This set will not have the proper decoding software to produce 5.1 surroundsound. sorry.
Sir,
I do not want to insult you in any way, but I must ask just in case it was overlooked! First check to be sure that the speaker settings on the stereo were not set all the way to the front. If that is not the problem, you can hook another speaker you know works to the wireing to the rear speakers to check to see if it is the speaker or the wireing. If you hear sound from the speaker you know works, then your speakers in the car are bad. If you do not hear sound, then it will be from the wireing. Next is the more difficult part. You will have to pull the stereo out and can splice into the wires. Hook the good speakers up to the splice and check for sound. make sure you know for sure the wires you splice into are for the rear speakers. If you still hear no sound, then it is more then likely a problem in the stereo itself. If you do hear sound then there is a problem in the wireing somewhere and may be easier to just run new wires to the rear speakers.
when the stereo or mono listening mode is selected only front speaker and subwoofer produce sound--------make sure that speakers are configured correctly. and you select surround sound in listening mode.
