Question about Paramount Cyclean Automatic In-Floor Pool Cleaner System Nozzle with Caps, Gray
Cleaners at bottom of pool dont pop up
Cleaners not popping up to circulate at all even in clean mode or any mode
  • Paramount Master
  • 1,631 Answers
Filter could be dirty?, clean or backwash.
or... You could have some debris: sand, grit, pebbles, etc. in your separate rotor valve assembly. There are small gears in there that turn the rotor plate, it allows for water to enter each set of pipes in a certain timed cycle. If those gears don't turn correctly, water won't flow alternately into those pipes that lead to each pop up head.
Posted on Jun 10, 2015
SOURCE:
The pump does not circulate water after priming
Make sure you are in pool mode, and if you are not circulating, then you have a clogged impellar. Make sure the basket is empty and good, clean the impellar, backwash, or clean filter, put valves into pool mode, prime pump, and you will be ok.
Jan 05, 2017 | Pool & Spa
My bug worked great last season but this year I will find it stopped in the pool not moving, I will pick it up and push on the feet to get them running again and it will stop again, what do I need to
It may be that you have one of several possible problems that could be the reason for the symptom you are experiencing:
  • Low water flow thru circulation system
    • Dirty Filter
    • Baskets filled with debris
    • Clogged Pump Impeller
    • Clogged suction line between suction port and actual cleaner
    • Clogged/plugged cleaning unit itself
  • Worn gear assembly within the LadyBug
Jun 12, 2014 | Hayward Aquabug Above Ground Pool Cleaner...
My phantom remains on the water's surface and will not dive to the bottom of the pool. What do i need to do to have the phantom clean the bottom of the pool?
There is a switch on these pool cleaners that has options "top, bottom, and automatic". If you have the cleaner set to automatic and it is staying on the surface, try changing the switch from the automatic setting and put it on "bottom" until you get the bottom clean.
May 12, 2011 | Hayward Phantom Pool Cleaner Complete with...
I just bought and installed a new intelliflo variable speed pump and now my Hayward pool sweep does not move to the shallow end. It only cleans the deep end and even that is not cleaned well. It seems to...
Thank you for posting your question here on Fixya.com.
It is a pressure side cleaner...the booster pump only boosts the main pumps output pressure so much. Lowering the main pump output, the booster WILL NOT compensate by increasing its output. Lowering the pressure to the cleaner head will cause what you describe. Turn the new pump up to full speed to clean the pool then down lower to circulate water for chemical balance and maintenance.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Feb 13, 2011 | Hayward Navigator Pool Cleaner
Ray Vac cleans only in deep end
Make sure that your automatic pool cleaner doesn't have an obstruction in the hose that might not immediately be visible. This could cause it to circulate in one end of the pool. Also, check the water pressure to ensure that it has enough force to travel the entire pool.
Jun 27, 2010 | Jandy Ray Vac Pool Cleaner for Inground...
Filter pump running hot and water is not circulating. We have a 10 x 30 Intex inflatable pool. Also, pump keeps popping the circuit breaker
If your pool filter and pump are running not and not circulating, it sounds like either your pump is not primed properly, you have an impeller jammed/or broken, or you have something clogging the hose to the return line that is causing pressure to build up. Check all three of these and bet you will find your problem.
Jun 05, 2010 | Intex Krystal Clear Model 635 Pool Filter...
Paramount Cyclean Automatic In-Floor Pool Cleaner System Nozzle with Caps, Gray Logo
687 people viewed this question
Top Paramount Water Sport Experts
Marvin
Marvin
Tom Chichester
Bill Boyd
Are you a Paramount Water Sport Expert? Answer questions, earn points and help others
