Frigidaire 20.6 cu. ft. Top Freezer Refrigerator with Factory Installed Ice Maker Logo
Posted on Nov 01, 2007
Ice Maker Not Making Ice
I have a brand new Frigidaire refrigerator/freezer.  I have the water and ice in the front.  A few days ago, the ice maker just quit making ice and I have no idea why.  It is on and everything else seems to be working, but not ice.  I pulled out the tray and cleaned it and dried it off and put it back, but still nothing.  There is no water leaking or anything like that.  What should I do?
  • 1 more comment
  • Anonymous May 16, 2009
    I have the same problem as 123lee, what's the solution?
    Water not being fed to tray when metal arm is down; have water to valve, all else is normal.
  • Anonymous Mar 17, 2014
    NOT ABLE TO RESET FRONT PANNEL DISPLAY
  • Anonymous Mar 29, 2014
    We have a frigidaire model FRT18S6A 18.2 cu. ft. refrigerator that leaks intermittently, any ideas? It's not a constant leak. Doesn't appear to be any water between the back of the refrigerator and the wall. The appears to be coming from underneath the refrigerator but doesn't appear to be tied to anything the ice maker is doing. Thanks!
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 11, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
1437
Points
Ice maker was installed properly, when you put the arm down it doesn't call for water to fill unit. It doesn't make any kind of noises at all. The water is turned on and all plugs are in there are no kinks in the line but when the arm is truned down for it to call for water nothing happens
The is for a frigidaire refrigerator.Ice maker is all new..
A
Anonymous
Frigidaire 20.6 top freezer not getting cold
I have a Frigidaire GSI 26, ffor the last couple of days it has been making a buzzing sound that lasts about thirty seconds to a minute, today the freezer quit working. the compressor is hot, as is th
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
1helpful
2answers
Ice maker kitchenaid super ba is not working . Chilled water dispenses but no water seems to enter ice maker.
These will help.
Thanks,.
1helpful
Ice maker not making ice
Try changing the filter; our refrigerator did the same thing.
2answers
Ice machine will not even start the ice making process. can get water out of the door with good presure but no ice
You either have a bad ice maker or a bad water valve. It really depends on what your model # is and brand.
Ice maker not making ice after replacing water line.
Ice makers are a common problem. On many brands there is a reset button behind the plastic cover. However if you physically see Ice clogging your water inlet to the ice maker, this will without a doubt prevent the ice maker from making ice. Use hot water or a steamer to unclog the ice or you can leave the unit unplugged for a few hours to defrost the freezer. You should be able to hear when the ice maker cycles and lets in water. Note: if you're getting plenty of water out of your in door water dispenser, then it's NOT a water supply problem. You may need to check the solenoid that controls water entering the ice maker.
10 yr old Frigidaire ice maker stopped making ice
try forcing the cycle by manually triggering the cycle a few times. Sometimes you can detach the trip arm or turn the tray by hand by disconnecting it from the gear. There may have been a switch bumped to turn it off or the switch somehow jammed. Maybe check for freeze-up. If there is water in it, it's going somewhere.
Ice maker not making ice.
These Icemakers have plastic gears on the modules that are breaking, also some have thermostats that are malfunctioning. I recommend haveing an experianced tech look at the unit to see if you need the new upgraded indoor ice maker.
2answers
Ice maker doesn't work
I have the same problem. I've had the freezer for 2 years & ice maker just stopped making ice this week. Freezer works O.K.
1helpful
2answers
check to make sure the fill tube is not plugged with ice if it is not then i would guess the valve is shot
Top Frigidaire Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
john h
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
