There may be holes that allow air to leak out, causing abnormal pressure.
Dashboard is the key to control pumps and more.
Zodiac R0465400 Tank Bottom Assembly Cartridge Pool fix pool pump
The adoption of new replacement pump..
Try to tighten or lube intake union make sure seal is good then check top seal to pump basket if ok keep checking by turning off skimmers or main drain until ok if still does same you might need new seals in pump has it overheated or ran without water lately
