Sony Handycam® DCR-SR82 Flash Media Camcorder Logo
Kris Posted on Mar 25, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Trying to get timestamp to burn to DVD from flash camcorder
Recently found that Sony is phasing out their DVD camcorders and we have to make the switch to flash memory or hard drives. Problem is we usually enjoy a embedded timestamp that is recorded when finalizing a miniDVD. Although the timestamp is stored in raw footage of flash memory or hard drive camcorder, when you burn the recordings to a DVD they do not show up. The only way we have found to get the timestamp is to plug the camera into a recorder and record at one time speed as the camcorder plays showing the timestamp. Is there a faster way??? In some cases we have 2 or more hours of video so doing this recording is time prohibative. Unfortunately, the timestamp is critical since it documenting activities for a report.
masud
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Master 582 Answers
  • Posted on Apr 09, 2017
masud
Master
Level 3:
Renaissance:
Answers
582
Questions
0
Helped
245785
Points
2232
Button displayed on the top-left of the flip-out screen
Tony Parsons
Level 3:
  • Sony Master 6,405 Answers
  • Posted on Mar 25, 2017
Tony Parsons
Sony Master
Level 3:
Answers
6405
Questions
Helped
1650768
Points
20272
Trying to use a consumer camcorder for this kind of purpose is not likely to be the best option.
5 Related Answers
A
Anonymous
  • Posted on Jan 08, 2008
SOURCE: Sony DCR-DVD 108 disc won't play or record
u tooo have same problem .. i recorded my whole trip on Dvd RW now the camcorder or computer shows fileformat as RAW rather than VR.. plz suggest some solutions.. all i want is my recordings back
A
Anonymous
  • Posted on Feb 04, 2008
SOURCE: disc will not play... camcorder wants to format the disc and says it is empty.
After fiddling around with the camera, I ound out how to do it since I had the same problem.
1. Put the disc into your camera
2. press the "home" button displayed on the top-left of the flip-out screen
Anonymous
  • 377 Answers
  • Posted on Mar 15, 2008
SOURCE: Sony handycam dcr-dvd105
dear tonimo
if you was finish your recording, select menu and choose finalize
it can make your dvd can play in dvd prtable
oke
cropp
Anonymous
  • Posted on Aug 14, 2008
SOURCE: sony dvd handycam finalize problem
If your discs are rewritable, you could try putting your discs in your computer. Try opening the folders and try to open all the files. Some of the files may be your videos. If it opens your video player and plays your videos, wait until it plays everything to make sure that all your data were recorded in the disc. Copy everything in your computer and remove your disc. Try playing it again and if it works, then it's already ok. When you are planning to use it again, make sure that you format everything in the disc.
Anonymous
  • Posted on Aug 30, 2008
SOURCE: movie recording disabled
I have the same problem.  If you have taken the disk out of the re-corder, then you can no longer finalize the disk...and you will potentially lose the data on the disk.  Their only solution was to take it to a professional media service and see if they could recover it...what a joke...at no point in the manual does it indicate that you cannot remove your disk or face the potential of losing your recording...I lost the recordings of the birth of my son...I will never forgive that...
I have filmed with my sony camcorder on dvd-rw 1.4 gb mini discs and it will not read on any of my computers. How do I copy these discs to my computer so I can burn them on to another disc.
Well..., First make sure that your computer has a DVD drive (I'm sure you already know)
When you take the disk out of your camcorder, do you finalize the disk?? If I don't finalize it on my camcorder then I cannot replay it on a computer or a DVD player.
Just my 2 cents!!
Sony model camcorder DCR-HC40E
well if you were to burn them via windows vista, I'm sure you could do that directly from your computer, if not I'd just talk to a real person (custumer service line, a shop etc.)
6helpful
2answers
Unable to read dvd-rw from sony camcorder - wants to format
I had a similar issue. I could not read the camcorder dvd drive (sony hdr ux5) from my computer. I even tried several different computers, it reads the drive but cannot recognize the format. I made sure the disk was finalized, but did not help. Then I found the this article http://forum.videohelp.com/topic351360.html which suggested I down load CDRoller which I did (14 day trial version), finally I could read the drive on the camcorder dvd drive. Hope this helps you, if you have not fixed it already.
1helpful
Can NOT copy aN original DVD made from Sony Camcorder DCR-TRV27
Try Finalizing the DVD disc on the Camcorder or the DVD Recorder before trying to copy the DVD on the Computer.
How do I download from the Sony trv260 to the computer
I am trying to find out how to download from the Sony trv260 to copy in my computer or to burn a dvd
Dcr dvd 306e camcorder where can i buy flat flexi cables
hi, from here you will get replacement of flat flexi ribbon cable for your camcorder http://judy-hydigital.diytrade.com/
2answers
Sony DCRHC30
The problem with Sony is that they're always trying to push something proprietary and lock in their own equipment as a standard. It is not likely that you are limited to a Sony computer. It looks like it has both firewire and usb 2.0 outputs. Provided you have one, or both, of these on your computer, there are many choices for software which will do the capture and subsequent processing. A lot depends on how much subsequent processing you want to do.
2answers
Sony DCRHC30
Sony DCR-TRV38 - cannot burn movie to DVD
I found the best way of editing the footage from these cameras is to put the DVD disc into your computer and copy the contents of the VIDEO_TS folder onto another folder on your hard drive. The uses a video editing application which is specifically designed for the MPEG format. I would highly recommend the low cost "Womble MPEG Video Wizard" which is available for a 30 day trial at www.womble.com.
2answers
Sony DCR-TRV38 Transfering video to dvd at a high quality.
Wait a second. You have a DVcam which is at that quality so how can you get to DVD quality? You may need a better camera!
Top Sony Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
