Not able to change supervisor Password in bios as bios is not allowing me to reset the Password nor allowing me to load setup defaults Will removing and again putting the cmos battery would work?
SOURCE: Lenovo 3000 N200 battery not charging.
I just had the same problem. My battery had discharged to less than zero and would not start even though the power plug was in. I tried everything... but what fixed it for me was to remove the power plug, remove the battery, plug in the power cord and start the machine. Once the machine was already booted, I put the battery in and it started charging. Dont know if that will fix your problem, but it fixed mine.
SOURCE: lenovo g530 4151 - restore bios from USB or CD ?
Hi, What I would best sugget you if you this kind of issue is to restore your system to its original settings, just look for the small button just beside the power button on your keyboard, it has an arching arrow logo, that key is what we called One Key Recovery that would restore your system to its original factory settings. but just a hint it would also delete everything on your computer so consider bucking up every important files taht you have before proceeding with the recovery. also make sure that the ac adapter is plugin before you press the one key recovery button then it will give the options to choose from, just choose one key recovey then proceed with the factory default recovery, thats it it would now proceed with the system factory default restoration. If you still need some clarifications regarding this issue you could also call the tech support hotline of lenovo
US/Canada: Available 24/7 1-877-4LENOVO (1-877-453-
6686)
Australia: Available 24/7 1300-557-073
New Zealand: 9am-9pm Mon-Fri 0800-446-833. Hope that helps you.
SOURCE: how to remove bios password in lenovo 3000 y510
This information is intended for experienced users. It is not intended for basic users, hackers, or computer thieves. Please do not try any of following procedures if you are not familiar with computer hardware. I'll not be responsible for the use or misuse of this information, including personal injury, loss of data or hardware damage. So use it at your own risk.
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
SOURCE: i forgot my bios supervisor
Are you the one who set up the BIOS password? If not, unfortunately, there's no way for us to retrieved the password. The only way you can reset the password to default settings is to reseat the CMOS battery on the motherboard, its a circular thing that looks like a battery of a watch,sometimes a pin hold it, just detached it then wait for at least 30 minutes then connect it back again,
Note: Before you reseat the CMOS battery,make sure that everything is unplugged on the computer, like AC adapter,battery and all external devices...
Hope this will help...Your response is very much appreciated...
The most common way
that most of us know on how to reset or clear the BIOS password is to
physically remove the power from the computer by disconnecting the power plug
and then removing a battery for 30 minutes from the motherboard. Another way is
to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods
mentioned works because most motherboards use a battery to sustain the
BIOS/CMOS settings for the motherboards PROM chip. So by cutting off the
battery power, the BIOS/CMOS settings will be erased or When you boot up to the log in
screen type in administrator as user if you cant log in During the boot up process you
will see on the screen for a short amount of time a certain key to enter set up
press and hold that key to enter set up BIOS scroll to set user password or
supervisor password you can change or remove the password from there if you are
still unable to change your password you might download
http://download.cnet.com/%7Bvalue=http://www.download.com/ubcd4win/3000-2086_4-10550208.html
UBCD4Win is a bootable
"live" CD which contains software that allows you to change
paswords repair/restore/diagnostic
almost any computer problem also has a
bios reset tool which remove your password and BIOS password although you will
have to use a computer with an internet connection you will have to burn it to
a disk as an iso then change your firtst boot device to cd During the boot process you will see
on the screen to press a certain key to enter setup Press and hold that key
during the boot up process to enter BIOS the scroll down to advanced bios
features press enter change your first boot device to cd press escape then
press f10 to save to cmos to restart (note after you have removed the password
you must go back and change the first boot device to your hard drive)
Hope this helps
