Sony KP-51HW40 51" Rear Projection Television Logo
D
Donna Hamernik Posted on Apr 11, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I replaced the lamp and cannot get the message on the screen to go off about lamp needing to be replaced
Jack South
Level 2:
Scholar:
  • Expert 195 Answers
  • Posted on May 08, 2014
Jack South
Expert
Level 2:
Scholar:
Answers
195
Questions
0
Helped
35555
Points
350
You need to do a lamp time reset in the menu.
How do I know if my Sony 50e3000 lamp needs replace
Most common indicators are:picture may be dimmer or flickering, or no picture with lamp lite error code flashing, or message on screen indicating lamp needs replaced, lamp 1 year old or older.
1helpful
I got the 'lamp needs replacing' message. Ignored it. Now my tv screen is black when you try to turn it on and the blue button on the power button flashes?
You haven't replaced the lamp at time. Replace a new lamp along with its ballast and make a lamp time reset. If you wish to get more details about the lamp replacing procedure to Panasonic PTVs, check this link.
1helpful
Message on screen says lamp needs to be replaced then timer reset. Need lamp and instructions to reset timer
The lamp time reset will be or should be in the owner manual---Google the model number with keywords "lamp install" with the model number and the "manual" with the model number---Google can be a great help.
1helpful
2answers
Replaced main bulb in front but lamp button on front of tv is still blinking and tv won't show picture
The lamp timer on the Hitachi projector must be reset whenever the lamp has been replaced. The "Lamp" indicator on the display will light red or the "Change the Lamp" message will display when the lamp timer needs to be reset. Hitachi recommends that the lamp timer never be reset without replacing the lamp and to always reset the timer when the lamp is replaced. The message functions of the projector will not function properly if the lamp timer is not correctly reset.
  • Turn the power on. Press the "Reset" button for three seconds until the "Lamp xxxx hr" message appears on the lamp timer on the bottom of the screen.
  • 2
    Press the "Menu" button on the remote control while the lamp timer is displayed.
  • 3
    Press the left arrow button. Select "0" and wait until the timer display clears.
  • If this was helpful a vote on the thumbs up for the free advoce would be greatly appreciated. Thanks
    I replaced the lamp, but am unable to reset the lamp so that the projector works again. It keeps giving me the message that I need to replace lamp and reset timer. And then it turns off.
    1. Switch power ON, and press the TIMER button on the remote controller, or the RESET button
    on the control panel, for approximately three seconds. The 'LAMP xxxx hr' message will appear
    2. Press the MENU button on the remote controller, or the RESET button on the control panel,
    while the lamp timer is displayed. The 'LAMP xxxx ? 0 CANCEL' message will then
    appear.
    3. Press the and select 0, and wait until the timer display is cleared.
    2helpful
    I have a large screen panasonic tv. The lamp
    Turn On tv.
    Press and hold Volume Down button on TV Front and PIP/ SPLIT button on Remote at same time for 6 Seconds to reset Lamp Timer and tv will show you timer reset message screen.
    Hope this info will help you.
    Thanks.
    1helpful
    Zenith model D52wlcd projection TV has been saying replace lamp for several weeks. Has had a small pink spot in middle of screen. Now full screen is pink. is this a lamp problem or just DOA?
    The Lamp will no cause any color distortion. The "Replace Lamp" message comes up after a certain amount of hours after watching the TV because the lamp only last a certain number of hours before needing a replacement one.
    It sounds like a light engine problem. There is no quick fix, you need to replace the whole light engine which is very costly (light engines usually run at least $500) and time consuming (need to take whole TV apart to replace part).
    1helpful
    2answers
    Need instructions for lamp unit part number TY-LA2004
    the projector will not know that u have replaced the lamp!u will have to tell it that a new lamp has been installed
    to do this go to the menu & find reset lamp hours option & do a lampo reset.the lamp hours will reset to zero & then the replace lamp message will nt appear!
    Top Sony Televison & Video Experts
    Grand Canyon Tech
    Grand Canyon Tech
    ZJ Limited
    ZJ Limited
    matt martin
    matt martin
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
