Question about Troy Bilt Tb70ss Gas Trimmer
Primer bulb on weedeater won't prime
I've got a 1 year old troybilt weed trimmer. The primer bulb pulls a suction instead of pushing fuel to the carb. I changed the original, but to no effect. I also disassembled the carb. I looked clean with no obvious damage to any parts. Any ideas?
    New Friend:
When you prime the bulb it sucks gas from the tank with the small tube, any excess gassed pumped will be fed back to the carb via the big tube leading to the tank. If you prime it and the bulb stays pushed down, then you have a clog or kink. To fix , pull the small tube out of the tank through the fill hole. Pull off the filter on the end and put the tube back in the tank. If it primes, your fuel filter was clogged. If it still wont prime check the hose going to the carb and make sure isnt clogged or kinked.(take of carb and blow in it). If that doesnt fix it take off the bulb from the carb with two screws. The bulb assembly will come off too(rectange metal thing) Take off the two black gaskets, be carefull with them. Take off hoses from carb and bulb asembly. Blow carb cleaner in all holes and over surface. Put back together.
If the carb wont prime and the bulb isnt staying depressed. then you might have a bad bulb or carb gaskets. Make sure hoses are not cracked, cloged, or pinched.
Posted on May 29, 2012
    Problem Solver:
  • 5 Answers
Try reversing the 2 fuel lines going to the back of the primer bulb,it sounds like they may have got installed wrong.
Thanks
Posted on Jun 17, 2009
SOURCE:
I replaced my primer bulb on my craftsman weedeater an am not sure what line goes where on the primer bulb can you help also not the gas leaks out of carb hole where
In regards to which pipe goes where, it's simple. If you pump your primer bulb with the pipes off, one side will suck and the other side will blow. The suction side will link to the outlet on the carb. The blow side will link to the return to tank. The fuel line with the filter on it will link to the inlet pipe on the carb.
May 12, 2016 | Craftsman Garden
I'm trying to get an old weedeater/poulan 22" excalibur hedge trimmer running for my son. In the past someone has cut a fuel line going to primer bulb. I replaced that line and when I use the primer...
There are 2 different set ups for fuel lines on these 2 stroke carburetors. One has a remote primer/purge bulb and the other has the primer/purge bulb on top of the carburetor. Here are instructions on how both kind work and how to service them.
The small diameter line out of fuel tank (has filter in-tank on end) connects directly to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then "pushes" any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. This is the return line. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb. If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where sometimes the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank. Otherwise, the line should enter the tank for about 1/2" or so If you have any more questions, please post back. I will see your comment and be glad to help you,
Apr 23, 2011 | Poulan Ght225 25cc Gas Hedge Trimmer
I would like to how the fuels lines go on my sears craftsman 32cc weed eater. They rotten out and don't know how they go. I bought it two years ago so it's not that old. The model number is 358791072. ...
The small diameter line out of fuel tank (has filter in-tank on end) connects to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then pushes any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb.If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank
Oct 04, 2010 | Craftsman Garden
Need fuel line routing on 32cc gas trimmer
This is an ongoing issue for users, and rightfully so .On your machine.. Small diameter line out of fuel tank (has filter in-tank on end) connects to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then pushes any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Years ago on 2-stroke trimmers, primers were not even used,...you choked the carb with a slide lever and gravity let fuel enter the carb from above...a few pulls, a "pop"...slide it off of choke and away you went.
If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank.
Sep 03, 2010 | Craftsman 25cc Gas Line Trimmer
I bought a Poulan PPB100 at a yard sale for $20.00. I got it home and got it started and running but it leaked gas like no tomorrow. I took it apart to see what was needed and found that all the fuel...
This is an ongoing issue for users, and rightfully so. Small diameter line out of fuel tank (has filter in-tank on end) connects to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then pushes any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Years ago on 2-stroke trimmers, primers were not even used,...you choked the carb with a slide lever and gravity let fuel enter the carb from above...a few pulls, a "pop"...slide it off of choke and away you went.
Please vote on this solution.
Aug 28, 2010 | Poulan/Weed Eater No. Te475 952711797 17"...
A relative has a weed eater featherlite 20c and thr primer bulb doesnt keep gas in it,is it supposed to?and if so what is the cause?And it want stay running unless u keep it running wide open.Why is that?
The machine is having a fuel delivery issue The purge/primer bulb PULLS fuel from the fuel tank, thru the carb and then to itself it pull any air/old fuel in the carb...and the PUSHES this mixture back to the fuel tank. There are check valves in carbs that have the bulb on them..Deteriorated fuel lines clog a screen in the carb and the ethanol in the gas works to deteriorate the fuel pump and metering diaghram in these carbs...You have to start at the tank with the fuel filter and go from there.
I'd say from the running symptons that a diaghram kit is needed for the carb...they are cheap and easily installed.
Aug 12, 2010 | Garden
Craftsman weed trimmer primer bulb is working in reverse
Make sure the line is near the botto ofthe tank.Thanks you for asking and I hope it helps.Please leave me a 4 thumbs up.
Jul 19, 2010 | Craftsman 25cc Gas Line Trimmer
Replacing fuel lines on ryobi weed eater,need
Jul 10, 2010 | Craftsman Garden
I am replacing the fuel tank assy and purge bulb (i.e. primer) on my Sears Craftsman model 358.798940. The original plastic tubing was old and brittle and broke apart while disassembling, so I could not...
The order of fuel travel should be:
Fuel filter to fuel hose to Carb's Fuel Supply nipple. (On the main body of the carb)
Primer Plate Nipple on carb to fuel hose to Suction Nipple on Primer Bulb. (It must pull fuel thru the carb, not push)
Pressure Nipple on Primer Bulb to fuel hose to Fuel Tank Return hose.
When correctly installed, the fuel will be PRESSED into the fuel tank via the return hose when primer is pressed in . . . and SUCTIONED out of the tank and into the Carburetor when primer in released.
Hope this helps,
Dolf-
Oct 16, 2009 | Garden
I have a roybi 31cc weed eater and the fule line has become brittle and has broken apart. I need to know the layout of the new plastic fule line. I purchased a new fule line at Lowe's. I do not know wich...
STEP (1) The fuel supply line has the filter attached inside the fuel tank. The other end of that line goes on the carburetor's SUPPLY NIPPLE.
STEP (2) Determine the primer bulb's flow direction by pumping it under water. The unused nipple on the carb (IF STEP 1 WAS DONE CORRECTLY THERE IS ONE UNUSED NIPPLE STILL AVAILABLE ON THE CARB) will have a section of fuel line attached to it and running to the SUCTION NIPPLE (or pull-side, as some techs call it) of the primer bulb.
STEP(3) The final piece of fuel line goes from the OUTPUT NIPPLE (or push-side, as some techs call it) of the primer bulb and is routed back into the fuel tank as a return.
If plumbed properly, the primer should PULL fuel thru the carb and NOT pump any fuel into the engine. Excess fuel should be pumped back into the tank on each and every press of the primer.
Hope this helps!
Sep 28, 2009 | Garden
Troy Bilt Tb70ss Gas Trimmer Logo
24,241 people viewed this question
Top Troy Garden Experts
Neil Hancock
lnbn1975
Dave
Are you a Troy Garden Expert? Answer questions, earn points and help others
