Likely the battery needs charged and/or has given out, hence radio works but no lights or engine crank.
Typical battery voltage is 12.7 VDC at full charge but most engines will turn over and start with just under 12.0V.
Check battery with a Digital Multi Meter and if not over 12V connect external charger for an hour or so. Then disconnect charger and recheck battery volts. If not over 12V, youll likely need a replacement battery.
If under warranty have it repaired/replaced. If not under warranty then some basic troubleshooting. Most likely a battery issue howerver;
To test the fencer output you can power the fencer from either a standard 6V lantern battery (6V fencer) or a standard 12V automobile battery (12V fencer). You need to rig wiring observing polarity.
To test battery, remove and check voltage with digital volt meter.
A fully charged 6V SLA battery should read 6.2V minimum and a 12V should read 12.4V minimum. If a 6V battery measures 4 volts or less then battery has likely failed. Likewise if a 12V battery measures 10 volts or less it has likely failed. Before replacing a suspect failed battery, connect the battery to any standard 6V/12V automobile charger and see if it will take a charge. After the charging period;
If battery takes a charge, reinstall back in fencer and see if fencer output is hot. If fencer fails output, repair/replace fencer. Else verify the fencer is charging the battery. While battery is installed in fencer measure battery voltage with a digital volt meter. Typical minimum voltage is 13.5V for 12V and 6.7V for 6V. If fencer fails to meet minimum battery charging voltage, likely the fencer solar charging system has failed, repair/replace.
If battery fails to charge, likely battery is end of life. However fencer could still not work. Test fencer with alternate power source (see previous tests). If fencer ok, replace battery.
the radio runs off of a seperate battery source, so that wouldn't have any effect on this, i would first of all check the battery and charger with a multimeter and make sure that they are showing the correct voltage, if its a 12v battery make sure that they are showing at least 12 volts, if its a 6v battery make sure that its showing at least 6v
Either the charging adapter is faulty or the battery is worn out.
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
You have a couple of options here. Either your battery is dead and needs replacing as battery's these days aren't what they used to be. you will know this if you try to charge it off the bike and it won't take charge in this case change it. Or you have a problem with the regulator rectifier and again could need it replacing. Charge the battery up off the bike (if you can) and get a multi meter on it and make sure its reading at least 12v then put it on the bike and start it up. Put the multi meter on the battery when the bike is running and if the voltage goes down then its not charging from the engine. In this case you will need to buy a regulator rectifier.
Is starter engaging but is turning the engine slowly then not turning engine? (that's what I'm reading) If so, check both connections at the block and starter. If reading proper voltage 12v or better, check voltage across battery when in "start" if it drops below 9.5v the starter has failed. (you can turn the engine by hand...correct?)
