Contributor
- Posted on Aug 29, 2008
Re: nikon 440 pro staff range finder wont read distance
I just got mine to work. It was doing the same thing. I guess I re-set it. I figured there had to be some way to re-set it. So I pushed the mode button and the power button simultaneously for 30 second. Then it worked! Wooptidoo :)
need info asap we are in middle of bow hunting here.
I am having the same problem. It won't read anything past 12 yards.
Having same problem, no range in yds or metres, although the cross hair is there. Installed new battery and still no measurements.
RAD
I'm having the same problem. My Nikon Laser440 works sometimes under 20yds., never beyond 20yds. anymore. It shows a full battery and is only 3 yrs. old and lightly used.
IT SHOWS THE CROSSHAIRS,DOES NOT RANGE,THEN SHUTS-OFF WHEN YOU LET OUT THE RANGE BUTTON.
My range finder will read on a good target to 85 yards, but no farther even if the target is a house!
Will turn on but will not give yardage.
everything appears to be working? New Bttery, Mode select, Just won't read a yardage... Whatz Up????
I replaced the battery TWICE on my Nikon Laser 440 and all it dos is show me the cross hair than instead off giving me the range it shows 3 lines. I can change the meter and yard.
I purchased the range finder in 2007 and only used it for Archery season.
I put in a fresh battery and push power button but it does not range find. It just shows 3 dots.
My range finder will only read out to about 125 yards. I have put new batteries in it. It seems to read shorter distances every time I use it. [email protected]
The range finder only shows three lines with no distance when powered up. I changed the battery but got no improvement. I tried the re-set solution but got no change.
I too am having the same problem. I go through the reset sequence and it ranges at the end of the reset but not when I push the button afterwards. All I get is the cross hairs and the 3 lines with the YRD indicator.
unit is approx. 1.5 yrs old and will not display yardage even after reset.
display shows yd and m without probem just wont display numbers.
reticle is hard to see and everything eventually fades away. Nikon should repair these at no charge. i will not buy another nikon.
