My nissan murano SL 2005 goes in gear but it won't move either in D or R position. Kindly assist
You don't need to worry about the steering wheel with this as they are not connected to each other in any way.
Are you getting any changes at all? OK, with the engine running, does the car feel the same when you select D or R? Do you feel the car change slightly as the gear engages and the sound of the engine slow slightly as the engine connects to the transmission?
Or does the car feel the same and the engine sound doesn't change. Is it only the Shifter stick moving and the indicator light changing?
