Unfortunately, the web site given in the link above is no longer in service, so it may be difficult to find instructions other than those at the link.
Quoting from the link above: '
"Ten Peaks Tent by Quest
1) Lay out the tent flat on the ground, be sure to stretch floor to eliminate slack. Drive a stake into each corner loop, then drive the remaining stakes into the side loops.
2) Install the poles by first separating them by their color code. Yellow poles make up the center section. Red poles make up the right and left sides. Slide the yellow poles through the center pole sleeve. Slide the red roof poles through the right and left pole loops of the tent.
3) Raise the tent. Assemble the yellow upright poles and attach them to the yellow roof poles. Raise the center of the tent to its approximate height, by using the quick clamps on the bottom of the yellow center uprights. Assemble the red left and right support poles, attach the support poles to the roof poles. Place the side support poles on the ground near the side stake loops. Adjust the placement and the height of the poles until the tent stands firm.
House shaped tent is not an adequate description to make erektion suggestions.
Broadly speaking tents are divided into categories of dome, tunnel, ridge, bell or frame.
The ridge tent is sort of house shaped and the classic frame tent also, though this is usually referred to as a bungalow or perhaps chalet tent. None of these types peaks in the centre of the top and neither does a house, usually.
A small marquee peaks in the centre of the top and is also vaguely house-shaped but it seems somehow unlikely you have a small marquee..
It is also important to know whether there is an inner and an outer tent or flysheet and a sewn-in groundsheet, single pole, ridge pole, frame, fibreglass rods or perhaps an A frame.
I can't advise much without knowing what sort of tent you have but I advise you to practice, practice, practice and colour code or number each pole assembly. Bad weather when pitching for the first time is too late to be trying to read instructions and wondering which pole section goes where.
I also advise taking extra pegs and guy ropes in case of accidents or really foul weather. Tents are provided with minimum equipment for moderate weather pitched on hard packed loam type ground.
For different types of ground; sandy soil or rocky different designs of pegs are available and should be used along with heavy stones or sandbags. Double pegging is also advisable in some circumstances.
Preparation and attention to detail is the key to a successful camping trip. No extra precautions often turns a simple camping trip into pure misery. I once camped at the top of a high cliff when bad weather was expected. I double-pegged and fitted extra guy ropes and slept right through a gale while my companion laid awake petrified. The tent never moved but in the morning we were the only campers left on that part of the site.
Step 1
Remove the tent, poles, stakes and tent rope of the dome tent from the Northwest Territory sack. Locate a large flat area and remove any sticks and rocks from the ground.
Step 2
Lay the tent fabric on the ground with the bathtub style floor face down. Pull the corners of the fabric tight and rotate the tent so the door is facing in the direction you want. Use a hammer to stake the corners in the ground.
Step 3
Assemble the two long poles to their full length. The pole segments are connected by chords and will easily snap into place. Slide one pole through the diagonal sleeve on the top of the tent. Slide the other pole through the other diagonal sleeve to form an "X" with the poles.
Step 4
Place the end of each pole in the corresponding grommet. The poles will bend and the shelter will be erected.
Step 5
Assemble the two small poles. Slide one pole in the doorway sleeve and the other in the back window sleeve. The poles will bend slightly to create a rain peak on the door and window.
Step 6
Pull the doormat tight and pound stakes through the loops on each corner. Pull the tent rope tight on the back of the tent and pound a stake through the rope loop to anchor the tent to the ground.
Step 1
Choose a spot to set up your tent. Look for level ground that's
free of large rocks or other debris. Make sure you're safely away from
your campfire. If it's possible, pitch your tent away from your kitchen
area as not to bring animals too close should they be attracted by the
smell of food. Once you've chosen a spot, clear the ground of small
rocks and sticks to give you a comfortable floor to sleep on.
Step 2
Unroll your tent. Put the rainfly and poles aside. Open the tent
body so it lays flat on the site you chose. Orient the door so it faces
in an accessible direction.
Step 3
Take out the tent poles. A basic Hillary tent will use two long
poles for the tent body and one short pole of the rainfly. Assemble the
two long poles and thread them through the pole guides on the tent body,
attaching them to the holes in each tent corner to raise the tent.
Step 4
Open the rainfly. Assemble the shorter pole and guide it through
the top of the rainfly. Place the rainfly on top of the tent and secure
it to the bottom of the tent body with the attached hooks.
Step 5
Stake down your tent. You don't want to be surprised by a storm in
the middle of the night or while you're away from camp. Stake your tent
even if the weather is clear when your arrive. Use a stake at least in
each corner of the tent. Find a rock to hammer them firmly into the
ground.
General tent setup instructions:
thread assembled poles through sleeves
connect one end of poles into tent corners
1 by 1 connect the other end of the pole, work front to back and the tent should assemble quite easy.
